SOURCE: HITACHI 53SBX59B, projection lights don't line up.
It sounds like bad solder connections in the convergence output circuit. It may also be an intermittant convergence output ic which will need to be replaced.
SOURCE: Convergence on top of screen and 3D bended lines (yellow & pink lines).
It is failure of convergence out ICs causing 3-D type picture on screen, you need to replace two big ICs in convergence section on main board.
Click Part Store to see an image of IC as well as price info.
If you need service manual of 43FWX20B, let me know to provide you a copy.
Thanks.
SOURCE: projection lights don't line up
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
Example Photo:
You can see more examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
SOURCE: i have a light blue and yellow line at the top and
You need the convergence board reworked. See www. TvRepairKits.com and see if they have a repair for you! Thanks for asking.
