Most of these kettles switch off when steam pressurises the kettle chamber and is forced down a tube (normally in the handle) to a bi-metallic temperature sensor/switch which turns the kettle off.
Two very simple things to check -
Have you removed the scale filter or is it damaged? If you have the pressure will not build up, so the temperature sensor will not trip.
Have you over-filled the kettle? If so water can get into the steam tube, this condenses the steam so the sensor takes longer to react (this is particularly the case if you fill the kettle with it tipped back toward the handle)
To state the obvious, the steam sensor has failed. Unless you are quite adventurous, and confident dealing with electrics, there's nothing for it but to get a new kettle (unless the kettle is still within warranty, in which case you should be entitled to a replacement of course).
