20 Most Recent
Morphy Richards 43691 Cordless Electric Kettle Questions & Answers
My morphy richards accents kettle
Get a new one. This is a result of electronic component failure or a tripping of the varistor that controls how hot the kettle gets. It is failing as a prevention for fire. This is a built in safety and should not be bypassed.
How do you clean the
if you wish to remove limescale, then you can use limescale remover either liquid or powder.
follow directions on the product of choice.
alterativly use vinager, just pour undiluted vinegar into the kettle and let it rest for a while until it no longer produces bubbles. then rince well.
if there is still limescale then repeat the process.
Note
do not let the kettle boil with vinegar or limescale remover in it. they may cause a fault and some
very bad smells.
I hope this was useful..
Hi there Hiw can I turn off the whistle on the
You can turn off the electronic whistle on the morphy richards kettle by moving the switch (marked with a musical note) which is located underneath the electric base unit (not on the kettle itself).
I have a morphy Richards 732007 super vac and the hand held device keeps beeping and flashes green lights when start button is pressed
The beeping and flashing green lights on your Morphy Richards 732007 Super Vac handheld device could indicate a specific error or issue with the device. Here are a few troubleshooting steps you can try:
- Check the battery: Ensure that the handheld device is fully charged. If the battery is low, it might cause the beeping and flashing lights. Charge the device according to the manufacturer's instructions and try again.
- Clean the filters: Clogged filters can impact the device's performance. Remove and clean the filters according to the user manual's instructions. Make sure they are completely dry before reattaching them.
- Check for blockages: Inspect the nozzle and suction pathways for any blockages or obstructions. Clear away any debris that might be interfering with the device's operation.
- Reset the device: Sometimes, a simple reset can resolve minor issues. Turn off the device, remove the battery (if removable), wait for a few minutes, then reinsert the battery and turn it back on.
