20 Most Recent
Russell Hobbs 14339 Cordless Electric Kettle Questions & Answers
When filled with water & put on to boil it
I think you would only solve this problem by cleaning the thermostat contacts, or replacing the thermostat which wouldn't be worthwhile as it's likely to be cheaper to buy a new kettle.
Besides this , just getting into the kettle needs special 3 tongue screwdriver and then a certain technique to open it up without damaging the plastic parts. Im'e afraid its a throw-away world now and its not good .
I have a Russell hobbs 19001 not working
If your Russell Hobbs 19001 appliance does not turn on even after replacing the fuse, there could be a few potential causes for this issue. Here are some troubleshooting steps you can take:
- Check the power source: Ensure that the appliance is properly connected to a working power outlet. Try plugging in another device to verify if the outlet is functioning correctly. If possible, try using a different power cord to eliminate the possibility of a faulty cord.
- Inspect the power switch: Examine the power switch on the appliance for any visible damage or issues. Make sure the switch is in the "on" position and not stuck or loose. If you notice any problems with the switch, it may need to be repaired or replaced by contacting the manufacturer or an authorized service center.
- Reset or check for a safety feature: Some appliances have built-in safety features that may cause them to stop working under certain conditions, such as overheating. Check if your Russell Hobbs 19001 has a reset button or an automatic safety shut-off feature. Follow the instructions in the user manual to reset or troubleshoot these features.
- Contact customer support: If none of the above steps resolve the issue, it is recommended to contact Russell Hobbs customer support or an authorized service center for further assistance. Provide them with details about the problem and any troubleshooting steps you have already taken. They may be able to offer additional guidance or suggest further troubleshooting or repairs.
Russell Hobbs RHCC5001 carpet washer. The cleaning solution is not coming out?
If the cleaning solution is not coming out of your Russell Hobbs RHCC5001 Carpet Washer, there are a few potential causes for this issue:
1. Check the Solution Tank: Ensure that the solution tank is properly filled with cleaning solution. Sometimes, the solution may not dispense if the tank is empty or the level is too low. Check the tank's fill level and refill it if necessary.
2. Unblock the Solution Path: It's possible that the solution path or nozzle may be clogged or blocked. Carefully inspect the solution dispenser nozzle and any associated tubes or hoses for any obstructions. Use a small brush or pin to remove any debris or buildup that may be blocking the flow of the cleaning solution.
3. Prime the Pump: If the carpet washer has been unused for a while or if the cleaning solution has dried up in the system, it may be necessary to prime the pump. Fill the solution tank with warm water and let the carpet washer run for a few moments to allow the water to flow through the system. This can help clear any blockages and prime the pump for proper operation. Once the water flows through smoothly, empty the tank and refill it with the cleaning solution.
4. Check the Spray Settings: Ensure that the carpet washer's spray settings are adjusted correctly. Some models have adjustable spray settings, such as low, medium, or high pressure. Make sure the spray setting is appropriate for the cleaning task you're performing.
5. Clean or Replace the Spray Nozzle: If the spray nozzle itself is clogged or damaged, it may need cleaning or replacement. Refer to the user manual or contact the manufacturer for specific instructions on how to clean or replace the spray nozzle on your Russell Hobbs carpet washer.
If you have attempted these troubleshooting steps and the issue persists, it is recommended to reach out to Russell Hobbs customer support or their authorized service center for further assistance. They should be able to provide you with more specific guidance based on the model and help you resolve the problem.
Russell hobbs kettle
You will need to first shock that kettle first bold hot water then remove it and replace with very cold or ice water. The smell like plastic is brought by the Plastic which over heats and somehow weakens to a point of melting thus releasing a smell into your water, Shocking the kettle would help if not then you will need to buy another kettle as that one might not be original or just wasn't tested for regularities and standards.
