20 Most Recent Russell Hobbs 10617 Glass 2-Slice Toaster Questions & Answers
Russell Hobbs 10617 Power Supply Issue
Usual culprit is dry capacitors.
1/3/2022 12:47:55 AM • Russell Hobbs... • Answered on Jan 03, 2022
What Tool Do I Need To Open Russell Hobbs Glass Toaster
Take a look through these... See if you can figure out which of the many models are available... Pick ONE. We could be helpful... If you let us... Results 1 7 of 7 We can help... you WILL be proud. Carnac the Magnificent
5/17/2021 2:14:57 PM • Russell Hobbs... • Answered on May 17, 2021
How to take apart a Russell Hobbs 10617 Glass 2-Slice Toaster
You can access it from the side where the lever is, pull out the knob, remove the edge panel, remove the plastic cover and you will get to the lever and the electromagnet. Most likely the contacts have become dirty clean them up and also remove all bread crumbs from there 0-02-07-24db95e967e3a1b405ddc74bbf3d2d745d4e06787f02e8617d2636ca5249acc2_8e5c2626-undefined-undefined-0.jpg 0-02-07-77a87cfc40088664b7ecf814e7b3325eb6b75d19f8524f2d90f63c5d7418fd22_5652bc8d-undefined-undefined-1.jpg 0-02-07-a35b721c412be48dedee904b9d335950c41af1914c00e9cd306590962e70d01e_f4c5ef99-undefined-undefined-3.jpg
5/17/2021 2:05:14 PM • Russell Hobbs... • Answered on May 17, 2021
2answers
Russell Hobbs 10617 led bar
may have screws on the bottom and the loader knob usually has to be pried off. Place soft wood like a ruler against the housing and pry carefully from side to side with a large screwdriver. After working on it, plug it in outside to a ground-fault ac plug on a fireproof surface to test.
5/12/2016 4:58:29 AM • Russell Hobbs... • Answered on May 12, 2016
2answers
I have a problem with
I would advice you check the user manual manual for this, because i cannot tell specifically the IC that is worn out, all you need to do is remove the IC, look at the top of the IC, you will see the number written on the IC, besides, you can take the IC to any electronic workshop to get the exact IC of your device.
Take care.
11/3/2014 11:41:58 AM • Russell Hobbs... • Answered on Nov 03, 2014
0answers
0answers
Repair
Be the first to answer 7/2/2013 3:13:52 PM • Russell Hobbs... • Posted on Jul 02, 2013Be the first to answer
I have a 10617 2-slice
Hello, jonI was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about toasters andpossibly yours, from repair to trouble shooting it. http://home.howstuffworks.com/how-to-repair-small-appliances1.htmPlease if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.Thanks, Mikehttp://beta.fixya.com/users/mc1bean
10/28/2011 11:09:55 PM • Russell Hobbs... • Answered on Oct 28, 2011
I need a user instruction
You can download the instruction manual by clicking on the following link.(http://www.russellhobbs.co.uk/pdf/product_236_14356.pdf ).Please don't forget to rate me if satisfied.Good Luck.
6/8/2011 6:14:52 AM • Russell Hobbs... • Answered on Jun 08, 2011
0answers
Heats on one side only
Friend,
Obviously only one side is getting current or only one element is functional. Eitherway, please open the sides of the toaster on the nonfunctional side and check if the wiring to the element is ok. If connections are OK then the element may have got burnt. Please replace it and reconnect the wires and close the sides.
2/22/2011 5:25:48 AM • Russell Hobbs... • Answered on Feb 22, 2011
The Stop function is allways
Click on the link below to read the solution to this problem:
http://www.fixya.com/support/t1187710-lever_not_stay_down
1/11/2011 12:20:00 PM • Russell Hobbs... • Answered on Jan 11, 2011
I have just bought 10617
It sounds like the unit has failed, I don't know what you could possibly do at your current location. You are going to at least need a new heating element and replace it, and if you are going to do that you may as well get a new one. You can contact the manufacturer and claim a warranty on it and they will ship you a new one, that is your best bet if there is no possible way to return it.
Thanks
Tim
10/10/2010 1:14:04 AM • Russell Hobbs... • Answered on Oct 10, 2010
4answers
Lever does not stay down
Buy a new toaster.
After a week or two return the broken toaster to the shop saying it won't work and ask for a refund.
9/13/2010 7:37:14 AM • Russell Hobbs... • Answered on Sep 13, 2010
5answers
What is the part number
9/4/2010 3:29:28 PM • Russell Hobbs... • Answered on Sep 04, 2010
My toster does not ssstay in ON position. The IC
An integrated circuit constructed to provide control functions to a toaster oven cooking appliance. The control functions including compensation for input voltage fluctuations, compensation for residual heat due to recycling, audible signal generation, multiple mode selection, safety shut off and others. The integrated circuit also provides flexibility to accommodate multiple models of an appliance in a product line. If you have the tools and the part, you can fix it yourself otherwise to the repair shop
10/29/2009 9:31:53 AM • Russell Hobbs... • Answered on Oct 29, 2009
Russell Hobbs 10617 Glass 2-Slice Toaster Logo
Popular Tags
34 questions posted
Top Russell Hobbs Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
ADMIN Andrew
ADMIN Andrew
Tom Chichester
Are you a Russell Hobbs Kitchen Appliances - Other Expert? Answer questions, earn points and help others
