SOURCE: Russell Hobbs kettle element model 10413
The only way to get hard to find Russell Hobbs electric kettle parts is from Russsell Hobbs. They will not sell any parts that are in short supply or becoming obsolete. Please visit their website, follow the instructions for repair and send the unit to them.
SOURCE: kettle will not heat. Russell Hobbs corded
Check mains fuse, if ok check for voltage at kettle , with multi meter, not phase tester as these can be faulty, if you have power and no heat then it has to be the switch or the element, check and replace same. if your unsure have an electrician do it for you
SOURCE: My Russell Hobbs microwave will not generate heat
If everything else is normal, the trouble may be a failed magnetron tube (the microwave source), problems on the control circuit board, or parts in the tube power circuit that are bad. It's also possible a door switch can be at fault, but this usually keeps something else (fan, turntable or light, most often) from running as well.
Microwave servicing is best left to professionals. There are potentially deadly voltages present, and a chance of microwave leakage if repairs aren't done correctly. Take the oven to a shop for an estimate, or just consider replacing it if it isn't a built-in, an over the range unit or a high-end countertop model.
SOURCE: Have you got a manual
Check if this link helps:
www.kitchen.manualsonline.com/ex/product/headline/m/???russell_???hobbs/d/slow_cooker/p/???13792
