20 Most Recent Morphy Richards 43072 Cordless Electric Kettle Questions & Answers
Our kettle light comes on but not boiling water
Morphy Richards... | Answered on Nov 06, 2016
You could buy in any grocery shop and in the net any brand of KETTLE and THERMOS DESCALER! Just put it in ur electric kettle and leave it for a day, it will disslove those lime scales! Taah!
Morphy Richards... | Answered on Jul 23, 2015
hello,
the chemical taste of smell from your kettle means that the element in the kettle which provide heat to boiled the water has gone bad due to over heating
this occur when there is shortage of water level in the kettle when the power supply is on
to fix up this problem of smell and chemical taste in your boiled water you will have to make a change of the element (heater)because it has gone bad you can get a replacement of it in the store .
thank you and thanks for using fixya.
Morphy Richards... | Answered on Jan 24, 2015
There is a therm o guard in there looks like a bullet. anything that has a heating element has one. mouser electronics sells them.
Morphy Richards... | Answered on Oct 20, 2014
Please use a multimeter and check the continuity of the power cord , now switch on and test the coils resisitance. If there is no continuity then the coil is open and the element has to be changed.
You need to contact spares dept of murphy richards.
please check the link below for spares;
http://www.espares.co.uk/search/kettles/p/1102
Morphy Richards... | Answered on Sep 20, 2011
try opening the plug.
Morphy Richards... | Answered on Jul 11, 2011
Run 5 to 6 pots of freash water through it. fill it, heat it, let it cool, and repeat.
Morphy Richards... | Answered on Mar 19, 2011
Visit
http://www.morphyrichards.co.uk/DownloadSearchResults.aspx?G1=G12
and check if there is a similar kettle to yours,
if not contact
http://www.morphyrichards.co.uk/CustomerCare.aspx
and request the manual.
Morphy Richards... | Answered on Jan 15, 2011
Hi trent7796,
If solid black lines occur on printed page, check the following:
If it is a laser printer, take out the toner cartridge. Check it is not damaged. If damaged replace it with a new on.
Clean the inside of the printer following the instruction manual. You may need to clean charge corona wire, Also check the rollers, as there may be a leak from your cartridges and dripping onto the rollers and causing the black line on your paper. A damaged fixing unit or hot roller also produce lines on paper.
Inkjet printers give this problem if print heads is broken. check that out.
Run a cleaning program to clean and realign the heads.
Last thing you are probably doing is using 3rd party cartridges. Sometimes they are of poorer quality over the factory. Try switching to the factory.
And Thanks.
Morphy Richards... | Answered on Mar 12, 2010
Lid probably leaking steam
Morphy Richards... | Answered on Mar 26, 2009
Morphy Richards 43072 Cordless Electric Kettle Logo
Popular Tags
29 questions posted
Top Morphy Richards Kitchen Appliances - Others Experts
Mike
john h
Andrew Taylor
Andrew Taylor
Are you a Morphy Richards Kitchen Appliances - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Morphy Richards Kitchen Appliances - Others
Most Popular Question
kettle not boiling water
  • Kitchen Appliances - Others
