20 Most Recent Breville "Ikon" Tea Kettle Electric Kettle Questions & Answers
Breville tea kettle won't turn on
anon.nick-20625 was right.
Opened the bottom of the kettle, not the charging base, using the three odd screws.
Found the white trip switch, which was a white line in the socket which connects the kettle to the charging base. Pressed it with a screwdriver and it came out more. Tested the kettle, works!
Hero
3/29/2020 9:03:24 AM • Breville "Ikon"... • Answered on Mar 29, 2020
2answers
Kettle doesn't turn off
Our first Smart Kettle was great and worked well for years, finally died so we bought another. Right from the first boil it seemed to boil for about 2 or 3 minutes before turning off and then either didn't boil or made beeping sounds when not being used so after a couple of weeks we returned it and it was replaced. Great. But now this new one seems to boil and boil before turning off so maybe they are just faulty now. Any suggestions?
6/8/2017 7:15:07 AM • Breville "Ikon"... • Answered on Jun 08, 2017
Cushion lid release button sticks and the lid does
Over time the heat can causes the plastic parts to swell until the button that releases the lid gets stuck. The button can be easily & carefully pried completely out of the hole with a knife **note the orientation of the button and spring for replacement. Clean the button & hole but expect the button to still stick when re-inserted back into the kettle. Take the button back out and if you take a knife and gently carve/scrape away some of the plastic round the inside of the rim of the 'hole' and around the edge of the plastic button, you can remove enough of the plastic so that the button now moves easily back and forth in the hole releasing the lid. Good luck.
6/4/2016 3:26:37 AM • Breville "Ikon"... • Answered on Jun 04, 2016
2answers
How to clean the inside of tea pot (scale
Vinegar is very good at removing scaly deposits. Heat white/clear vinegar just as you would normally heat the water for your tea. After heating the vinegar, pour out and rinse thoroughly with water. If there are still deposits after this first attempt, use vinegar once again. Once you are satisfied that all the deposits have been removed, heat water in the tea pot 2-3 times to remove any smell or taste from the vinegar (before using for tea).
12/18/2014 11:44:50 AM • Breville "Ikon"... • Answered on Dec 18, 2014
Breville Bread Maker Instruction Manual Model br2
Probably too old for support. A breadmaker is a breadmaker so most recepies and instructions will be similar.
9/18/2022 8:00:45 AM • Breville Kitchen... • Answered on Sep 18, 2022
I have a BREVILLE HALO ROTISSERIE AIR FRYER, but when i try to use it the code :E03 shows and stops running. I believe its a venting issue but not sure how to fix it. Anyone know
What Should I Do If My Air Fryer Displays The E3 Error Code? When an air fryer is overheating it's imperative that you unplug it from the socket and let it cool down for 15-30 minutes before you start it again. It's most likely caused by excessive oil or food. An air fryer's basket shouldn't be stuffed to the brink as it will cause the air fryer to overheat. They're designed to operate at no more than 400 degrees Fahrenheit, adding more oil or food than recommended can raise the temperature even further. More here https://www.google.com/search?q=BREVILLE+HALO+ROTISSERIE+AIR+FRYER%2C+error+code+%3AE03 ..
5/18/2022 7:20:29 PM • Breville Kitchen... • Answered on May 18, 2022
Doesn't beep when toast is done.
Bad beeper? Some go to extraordinary lengths just to turn off the function. You could contact Breville customer service to see what they might be willing to do, even if out of warranty. This is not a feature you can toggle! Look at what one party goes through just to kill the feature. https://www.fixya.com/support/t3566901-turn_off_annoying_beep_when_toast
3/13/2022 10:08:06 PM • Breville Kitchen... • Answered on Mar 13, 2022
Breville Breadmaker Model BB290 - not working
Sounds like the motor has failed. That part doesn't appear to be a spare, and they even charge you $45 for the security screwdriver. The problem is that because you don't use it, it has failed, and now limited spares are available. reckon it is time to cut your losses and buy a new one or make bread by hand like I do :>) http://spares.bigwarehouse.com.au/index.php?cPath=64928_68442_80475 Videos may help https://www.google.com/search?q=Breville+Breadmaker+BB290+replace+motor& Strange text help, but he sells spares https://spares.bigwarehouse.com.au/common_faults.php?cPath=64928_68442_80475 ..
10/17/2021 2:13:01 AM • Breville Kitchen... • Answered on Oct 17, 2021
Need a manual and recipes for Breville bakers oven deluxe model no 370. I know it's old but hardly used
old being the key word , I doubt you ever find a manual
6/2/2021 1:58:29 AM • Breville Kitchen... • Answered on Jun 02, 2021
2answers
Need a instruction book for breville cyclonic super wizz of 12
ask Breville directly we do not have that
5/8/2021 4:47:01 PM • Breville Kitchen... • Answered on May 08, 2021
Breville crystal clear water kettle repair. Kettle does not heat anymore. The heating element inside is OK. Maybe it's the thermostat switch controlling the on/off switch?
I am wondering how you know the heating element is ok when in order to gain access to the terminals in order to check it for continuity, you would have naturally checked the circuit to the element as you dismantled the kettle... It probably isn't the switch but of course it might be... The new fangled disc elements aren't as long lasting as the traditional type and there is probably a thermal fuse buried somewhere inside close to the element. If it is a cordless kettle, perhaps power isn't being delivered to the kettle from the base.
1/20/2021 11:11:12 PM • Breville Kitchen... • Answered on Jan 20, 2021
Breville kettle blew fuse (trip switch) now won't switch on
If the 'neon' light is on, the power is getting to the kettle, so if its not heating up then the element must have broken.
This kettle has a little white trip switch inside the 'socket' of the kettle (not the base unit). If its not heating, light is not on and the plug fuse is OK, then poke the white trip until it clicks.
12/16/2020 12:04:37 AM • Breville Kitchen... • Answered on Dec 16, 2020
2answers
Manual for. Breville bread master BB350
manualonline.com or manufacturer.
11/16/2020 5:38:24 AM • Breville Kitchen... • Answered on Nov 16, 2020
I have been given a Breville Super wizz model FP 2a with no instruction manual, not even sure if all parts are there, can I get a photo of what the components are please
Is your requirement still current? I have the FP-2A with all patrs, I could possibly send pics if that is helpful.
11/2/2020 8:50:07 AM • Breville Kitchen... • Answered on Nov 02, 2020
Kitchen Appliances - Others Logo
9 questions posted
Top Breville Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Marvin
Marvin
David Shaub
Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Breville Kitchen Appliances - Others
Most Popular Question
breville tea kettle won 39 t turn
  • Kitchen Appliances - Others
