Both red and green lights are flashing. Manual says low toner may be the problem...copies not indicative of that. Printer shows as "offline". Disconnected & reconnected power and USB cords. Is Orange button "reset"? If so, it is stuck.
Hi
It maybe one of the fuse gone.
You have to change the fuse:
The fuse is 250mAh and 3/4" inch long (20 mm) round glass with metal ends. The electrical contacts are not in the cartridge but inside the printer: There is a plastic fuse holder on the cartridge, even the starter cartridge. You just simply pop it into the holder. This will stop the flashing red LED and the system tray will say the cartridge is full.
All The Best: Pineworks
Check the 1500uF @ 10V capacitor on the power board. That had failed in my printer and caused the exact same fault
Thanks for the hint @DavidFowler. I just fixed my Samsung ML-2510.
> David Fowler Aug 10, 2017
I just wanted to say thank you for this information. I had problems with this thing for years cutting out, and couldn't figure out why. I opened it up, and saw the slightly puffed top of that 1500uF cap, and for about $5, got a pack of them, and replaced it, and it works perfectly.
