You didn't say what camera you are using, check the specs for the camera and see if it can use a 2GB card. If the camera is not able to use that size card it will not "see" it.
Have you tried putting the card in a reader and formatting it on your computer?
If it the computer can't see it, the card may be bad.
I have a Sony Cybershot DSC T70 and it keeps saying "Reinsert memory stick" whenever I turn on the camera or slide down the camera lid. Also, whenever I try to view the pictures on my laptop it shows "Please reinsert the memory stick" something along those lines. As I have been researching for the solution, I would have to format the memory card. However, I wouldn't want to lose the pictures as I just took many as from the holiday last week. The only problem is the memory card, I tried using another memory card and it works fine with the camera. There is nothing wrong with the camera.\r\nCan someone please help me how to solve the memory stick problem? It would be great. Ty.
* copy all the images to your computer.
* format your memory card using the format feature on your camera
* Make sure the contacts on the card are not dirty
Either the card is bad or the contacts inside the camera are dirty or damaged.
Try another known good card...if that doesnt work, I would suggest you take it to a camera shop and have it checked out.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
