A Whirlpool dryer either heats or doesn't heat . This problem is an indication of a blocked vent hose , from the rear of the dryer to the outside vent outlet . Try removing the vent hose from the back of the dryer and dry a load , to verify this problem . Wet lint inside the hose also means the air cannot escape to the outside .
I have a Kenmore dryer and it runs but won't heat up and dry the clothes. I don't hear the ignition even turn over. Please help. I can't afford to buy a new dryer at this time.
try opening the door and seeing if the drum has shifted and is rubbing on the frt panel somewhere,it may have just shifted off the drum glides or bearing seat/the other one sounds as if the element is open(bad)if the other one heats fine,if both take long periods to dry clothes,ckeck for 120/240 at the main house panel and again same at dryer outlet plug-in receptacle
what type is this electric or gas? have you removed the exsaust from the wall and ran a load like this? if you have heat and this is an electric dryer it sounds like you have a blockage in your house. if the dryer runs fine without the exsaust attached then that is your problem. let me know
if replacing the rollers didn't fix the squeak, you need to replace the teflon drum slides and drum gasket material. mine sqalled so much it would run you out of the room. now it's quiet.
