I have a double jenn air expressions oven and the top oven works fine but the bottom oven has a message of "fr" whenever I try to use it. we had a technician come in and he said we needed part number 71003413 . To get the part and have it replaced is $400. the tech didn't really seem to know what he was doing he was on the phone the whole time and he said he never seen that error message before. model number ww27430wc
This appears to be a communications error between the control boards. There is a test mode that you can enter from the panel, which might help you diagnose the problem further:
1. Turn power at break off. Wait a few minutes. Turn power back on.
2. Push and hold "Stop Time" key for 10 seconds
3. Now you are in test mode. You can push each button to test it's function while you hold it down.
4. Push cancel to exit test mode.
If you conclude a control board failure is the problem then we may be able to save you some money. If you can have the board removed, we repair them at www.fixyourboard.com
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
