Question about Jenn-Air Ovens
Jenn-Air Maytag double wall oven makes loud buzzing noise
My wife and I bought a used, late model Jenn-Air double oven recently. Discovered that the control board was shot, so we replaced it with a re-manufactured one. Everything works fine now, except there is a loud buzzing noise coming from the top of the unit whenever it is in use. If I turn the oven off immediately after turning it on, the noise stops. But, if I let the oven heat up to cooking temps and then turn it off, the buzzing noise persists until the cooling fan shuts off. Is there a relay associated with the cooling fan that could be causing this noise?
    Champion:
  • Jenn-Air Expert
  • 220 Answers
There is a cooling fan for upper and lower oven they run at the same time no matter which oven in use it is fed from the oven manager no way to trouble shoot without pulling oven out some models use same fan for both so you could have a blower on hand remove back panels to access fans take a lead off fan to determine which one noisey
Posted on Feb 13, 2015
2 Suggested Answers
micromatikal
Tim Grayson
  • 2777 Answers
SOURCE: I have a Whirlpool double
Strange, I would have thought it was the thermostat (temp sensor as you call it).... It may be the actual electric portion of the control panel itself malfunctioning... There is not much behind the control panel that could buzz aside from the control panel itself.
Check out the part I believe you need here, this site is really handy for this type of thing:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5132068&diagram_id=930365#d930365
It is number 6 on that list there... the CNTRL-ELEC they call it. You sound very capable so I would say try and replace that, I bet it'll fix it right up!
Tim
Posted on Oct 01, 2010
Ron Clark
SOURCE: maytag oven blowing hot air from bottom vent heating house
Wanted to know if you found the answer. I have the same problem.
Posted on Sep 02, 2012
Jenn-air oven error code 4d22
Hi. Erorr 4d22 indicates that the control board isn't seeing the fan speed signal from the fan on that oven. It's the lower oven, right?
Check the connection to the Fan and Control board, and if that's not it replace the fan.
HTH.
Jul 25, 2011 | Jenn-Air Electric Double Oven
Jenn-air double oven - model # ww2780b I was using the top oven. It started beeping and F1 came up on the screen.
Your EOC electronic control is bad.
The part numbers are YO4100040 retail price $443.00
and part number YO4100264 retail price $208.00.
The repair requires both parts be replaced at the same time or risk damage to the EOC.
May 18, 2010 | Jenn-Air JJW8230D Electric Double Oven
Jenn Air wall oven won't cancel / shut off . Recently replaced membrane.
Hey - the ribbon link from membrane to control is a tricky plug to get in right- double check this connection and let me know if it helps- Thanks- Ed
May 13, 2010 | Jenn-Air WW30430P Stainless Steel Electric...
Jenn Air oven keeps beeping F2 and the upper oven broiler won't shut off. We do not have a manual. Please help!!! [email protected] (925) 672-1279
Sounds like a welded relay on the control board. You can replace the board or have the board repaired for much less expense.
Feb 20, 2010 | Jenn-Air JJW8230D Electric Double Oven
My clock and temperature display is dim
Hi, this will happen over a period of time and its just heat related. the control panel isn't insulated properly and , there has been a larger than normal transfer of heat to the inside of the control panel where the circuits are housed.
If this is a problem, i recommend replacing the control board. it will fix the dim issue.
May 22, 2009 | Jenn-Air JMW9527C Electric Double Oven
Jenn air oven
More then likely your electronic clock control board is going bad. After turning the power off, you can also try cleaning the connectors on the clock board and make sure the connectors are tight.
Mar 23, 2009 | Jenn-Air JJW8230D Electric Double Oven
Jenn-Air coolimg fan problem
Good Morning!
What youre experiencing could be a result of a faulty oven temperature sensor, a faulty oven control board or relay board. Youre more than welcome to send both the main control board and relay board for evaluation. Fixyourboard will test and repair both as needed for less expensive than buying new, and include a two year warranty.
5700M662 60 Jenn Air OVEN CONTROL BOARD
May 15, 2017 | Jenn-Air JJW8230D Electric Double Oven
Problems with Jenn-Air Electric Double-Wall Oven
that board supplies power to the light unit and it is very easy to replace if that is what is wrong. it can also be the led display unit also. cost about $150 each i think.
Oct 26, 2007 | Jenn-Air WW30430P Stainless Steel Electric...
Ovens Logo
730 people viewed this question
Top Jenn-Air Ovens Experts
Nathan Van Boven
Nathan Van Boven
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
