20 Most Recent Jenn-Air JJW8430DDS Stainless Steel Electric Double Oven Questions & Answers
There are a few Jenn-Air models. Can you please add the Jen-AIr model # in comments?
Jenn-Air Ovens | Answered on Nov 01, 2020
Hi
If you have connected correctly and the ribbon cable is also fine then it seems that the touch pad is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Jenn-Air Ovens | Answered on Apr 15, 2019
FR Second oven error sensed
The unit never detected a sufficient rise in temperature in the second oven.
Jenn-Air Ovens | Answered on Jan 24, 2019
wet shorted circuits
Jenn-Air Ovens | Answered on Dec 18, 2018
whenever you set an oven it always starts at 100,if that's an electric oven most likely the bake element is bad and the broil element is just working and heating up the oven,when you set the oven to bake both the broil and bake elements get hot.if it's gas most likely a bad ignitor,send the model number if you write back,also if that's an electric oven make sure you flip the breaker so there's no power going to the oven before you try to remove the element,i see people try to remove the element with the power still on and when they pull out the element the wires touch the metal and bang they short out the clock assy.kill the power,remove the two screws that hold the element in place or if this isn't a wall oven slide out the oven,unplug it,remove the back wall and with a meter read out the element,remove at least one of the wires first and then check it,very simple set your meter to 20k,ohms touch the leads to the element where the wires connect to it,if you see a 1 the element is bad or open,if you see anything else but 1 the element is good or closed,hope this helps you out
Jenn-Air Ovens | Answered on May 26, 2018
there's a door gasket that seals it not the metal part of the door so you might be able to stick your thumb in there as long as the seal on the door is closing tightly to the frame,when you open the door it should be on a 90 degree angle,before you had new hinges put on the door, most likely the door sagged lower to the floor and didn't close properly,if you think alot of heat is escaping you could have a bad door gasket.so open the door,look at it from the side,it should look like an L or at a 90 degree angle or even up a little,if it is the hinges aren't the problem if you think to much heat is escaping,call whoever did the work for you and have them check the door seal or gasket same thing.you didn't send the model number so i don't know what seal you need,go here and watch video should be similar and you can put your model number in to find correct part
http://www.appliancepartspros.com/whirlpool-gasket-oven-door-wpw10162384-ap6016005.html
hope this helps you out,if heat is coming out with door closed and you have new hinges this is most likely what's wrong
Jenn-Air Ovens | Answered on Feb 08, 2018
Jenn-Air JJW8430DDS Stainless Steel Electric Double Oven Logo
2 questions posted
Top Jenn-Air Ovens Experts
Michael Thomas
Michael Thomas
Paul Bade
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
View Most Popular
Jenn-Air Ovens
  • Jenn-Air Ovens
Most Popular Question
need specs cutout dimensions jenn air
  • Ovens
