Bad control board
It sounds like there may be a problem with the control board or circuitry in your Candy Grand Evo 8123D washing machine. The ticking noise could be an indicator of a fault in the machine's control system. To troubleshoot the issue, you could try the following steps: Unplug the machine from the power outlet for a few minutes, and then plug it back in. This may reset the control board and solve the problem. Check the power supply to the machine. Make sure that the power outlet is working and the machine is receiving the proper voltage. Check the door lock. If the door is not properly closed or the lock is faulty, the machine may not start. Check the machine's control board and wiring for any signs of damage or corrosion. If none of these steps work, it may be best to call a professional appliance repair technician to diagnose and fix the issue
