20 Most Recent Princeton Digital VL1919 19" Monitor Questions & Answers
try taking the batteries out or go to the shop where you bought it and go from there...good luck lol :-P
Princeton... • Answered on Oct 10, 2013
More likely to have failed DC filter caps, see pictures here: http://s807.photobucket.com/albums/yy352/budm/Princeton%20VL1918W/
Basic LCD monitor and LCD TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, Caps : http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you. Please post back what you find.
Princeton... • Answered on Jul 21, 2011
you can easily inspect the capacitors on the display and see if they are the fauly. Now does the screen work if you connect it back to the old machine, and do any other monitors work with this computer?
can you tell me more about the symtoms of this display, what does it do when you turn it on etc?
Princeton... • Answered on Mar 04, 2011
Look for bad caps with domed tops as shown here:
http://s807.photobucket.com/albums/yy352/budm/Princeton%20VL1919/
Capkits: http://lcdalternatives.auctivacommerce.com/Search.aspx?k=princeton
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on: Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed PRINCETON monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/ Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide: http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series. Please leave rating if it helps.
Princeton... • Answered on Feb 09, 2011
Unless the problem is in the monitor, more likely the PC video resolution is too high for the monitor to work. Please read here:
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
You need to set your PC video resolution to the native resolution of this VL1919,
Which is 1280 x 1024 @60HZ
Also watch out for the caps to go bad in this monitor also.
Basic LCD monitor and TV troubleshooting guide: http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Parts: www.shopjimmy.com Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps. Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series. Please post back what you find. Please leave rating if it helps.
Princeton... • Answered on Jan 12, 2011
Look for bad caps with bulging tops.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on: Basic LCD monitor and TV troubleshooting guide: http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Parts: www.shopjimmy.com Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps. Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series. Please post back what you find. Please leave rating if it helps.
Princeton... • Answered on Jan 07, 2011
Not sure if the VL1918 uses the same chassis as your, just remove the 4 screws and disconnect all the lamps connectors and other connectors.
http://s807.photobucket.com/albums/yy352/budm/Princeton%20VL2018W/
Can you post the pictures? so I can see what it is about.
bsims77010, Tell me brand name of electrolytic filter capacitors on the large "switch-mode-power-supply / CCFL inverter supply" printed circuit board. Are any of them SWOLLEN on the end that is up ??? You can see typical "failed units if you visit YOUTUBE for video clips that show owners/tech's that replace them with new ones and now have working units again. You must tell me more about this "keeps turning off" thing???? Is unit going to "black screen" only?? Or is it going to "black n blank" screen"??? There is a difference!!! If black only then 5vdc might be ok! If "black n blank then +12vdc & +5vdc sources could be in shut down mode. Do you see screen data with aid of bright flashlight held 1 inch from the "black" screen?? Once you have knowledge of what makes "raw white light" on reverse side of your lcd panel, then you will have clue to how the new screw-in, curlie-Q style CFL light bulbs work and what an "electronic ballast" circuit is. 12fixlouie
Post reply if you need further assistance.
Princeton... • Answered on Dec 15, 2010
There are various steps to fix this issue.
Step 1.
For Vista and Win 7 PC
1.Go to Control Panel - Power Options
2.On the Left side there is a column - " Click Change when the computer sleeps
3.Click the drop-down box which says Put the computer to sleep and select 'Never' for both battery and 'plugged in'
4.Click 'Save changes'
For Windows XP
1. Go to Start - Control Panel - Power Options
2. Under the Power Schemes Tab, set the Standby and/or Hibernate Options to 'Never'.
3. Click Apply/Ok and you're done.
Step 2
1. Right click on the desktop and click Properties.
2. Click Screen Saver + below you will find Power Click on that
3. You will see Settings for Home/Office Desk power scheme and in Turn off Monitor slect Never and click Apply.
Thank you for contacting FixYa
*Please rate this solution with Thumbs Up
Princeton... • Answered on Nov 26, 2010
Try it with anotehr PC first, otherwise will more likely to be bad caps: http://s807.photobucket.com/albums/yy352/budm/Princeton%20VL1918W/
Basic LCD monitor troubleshooting guide:
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you. Please post back what you find.
Princeton... • Answered on Oct 25, 2010
If you alsready try this with another PC (or box as you called it), then you will have to open it ups and see if it has any bad caps inside as shown here:
Princeton... • Answered on Oct 18, 2010
You need to verify to find out if it is the monitor is bad or the PC is not sending the video signal to the monitor. Try another monitor with the PC, if you still have the problem then you need to fix the PC, if it works OK then it is the monitor problem.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums http://en.wikipedia.org/wiki/Capacitor_plague
Princeton... • Answered on Oct 08, 2010
More likely the power supply had failed, but more likely that it is already on its way out due to bad caps, see pictures here:
As you can see, 99% of failed monitors are due to bad caps.
Princeton... • Answered on Sep 23, 2010
Remove the stand and all he screw from the back and the bottom edge. See my pictures fo VL1918 which is similar to 1919.
Princeton... • Answered on Jun 23, 2010
Common failure on the Princeton monitors are caps failure in the power supply, look for bad caps (bulging top or seal), see failed Princeton monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Princeton... • Answered on Mar 26, 2010
Try looking for bad caps first, see example of failed PRINCETON monitors because of bad caps here: http://s807.photobucket.com/home/budm/allalbums
Post back what you see so we can guide you further.
The ticking sound is from power supply turning on and off.
Princeton... • Answered on Feb 24, 2010
Princeton Digital VL1919 19" Monitor Logo
37 questions posted
Top Princeton Digital Computers & Internet Experts
Daniel Dollive
Daniel Dollive
Tom Chichester
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
VL Princeton Digital
  • VL Princeton Digital
Most Popular Question
blue light monitor flashes off but no
  • Computers & Internet
