The error code "A06 403" on the RZ200 duplicator indicates a problem related to the master-making process. This error can occur due to various issues within the machine. Here are some steps you can try to proceed with resolving the error:
Power Cycle the Machine: Turn off the RZ200 duplicator and unplug it from the power source. Wait for a few minutes, then plug it back in and turn it on again. This simple reset might clear the error if it was caused by a temporary glitch.
Check for Obstructions: Inspect the machine's internal components, such as the master-making unit, ink cartridges, and paper feed, for any visible obstructions or jams. Clear any blockages carefully.
Clean Internal Components: Dust and debris can sometimes cause errors in the duplicator. Clean the internal components, particularly the master-making unit, with a soft, lint-free cloth or a compressed air duster.
Inspect Master-Making Unit: The "A06" error code often relates to the master-making process. Check the master-making unit for any signs of damage or misalignment. Ensure that the master roll is loaded correctly and that all components are properly seated.
Check for Ink Issues: Inspect the ink cartridges to ensure they are installed correctly and have enough ink. Low ink levels or improperly installed cartridges can lead to errors.
Update Firmware (if applicable): If there is a firmware update available for the RZ200 duplicator, install it. Firmware updates can sometimes resolve known issues and improve performance.
Refer to the User Manual: Consult the user manual or the manufacturer's documentation for the RZ200 duplicator for specific troubleshooting steps related to the "A06 403" error code
Be aware that not all people would agree with my explanations ...
All inks for duplicators are nearly the same and therefore they are mostly interchangeable. Have a look at the DPI the ink is made for. Lower resolution ink may have bigger pigments and these may become stuck in the mesh of drum or the master. At least you have to fill the ink in an original bottle to use it. Avoid air bubbles!
Please weigh the risks before you continue. Techical difficulties may apply. So only courageous people should use foreign ink. - I have done often and my risographs still work very well!
The machine do not reconise the ink.At the back of the ink there is a electronic chip that tells the machine what tipe of ink it is.There is a problem with that chip or the ink is not compatible.Replace your ink in most cases this will solve it,but let me know if I can futher assist.
Thanks for supporting us.
T-4 is an ink overflow condition. You may need to check and clean out ink section of drum. Remove the ink then press reset button. Then turn off and on and re-insert ink.
