SOURCE: power problem rca 32v434t
RCA 32V434T likely has a bad flyback--#271996. RCA 32F531T flyback no longer available,#262343 Fix one,dispose of other.
SOURCE: Indesit Standard WIL 123 (UK) Washing Machine
Had a similar problem ,flashing red led means door not locked, I removed door from machine removed front from door and found hinge pin for lock had come adrift, religned pin and chapped back into position .THen replaced door and door to machine .dor shut and lock worked perfectly, hope this helps
SOURCE: Door Lock Light - flashing
does the door still lock? becasue it sounds like a faulty lock. It may need to be replaced.
SOURCE: PT-AE700U Lamp led flashes red
Reset the lamp hours. Here is the manual on how to reset lamp time.
http://www.projectorcentral.com/pdf/projector_manual_2606.pdf
Good Luck and Please Rate Fixya!
SOURCE: will not turn on
This might help you. Try starting on page 27 of this:
http://www.scribd.com/doc/6528782/Philips-42pf7320
