Question about Electrolux Washing Machines
How can I reset my electrolux washing machine afer an E20 error?
I have an electrolux EWF 1282. I got an E20 error at the end of program. Washing was still wet. Took out filter and cleaned. Put filter back. Wanted to start the program again but it just makes a ''humming'' noice as if water is not coming in and program does not start. Technician came out when still under warrenty and he basically reset it. How would I reset the machine. thank you kindly
Posted by jaxb214 on
Anonymous
    New Friend:
Turn the dial to off. Press and hold the start pause and the nearest option button. While you're holding them down, turn the dial one notch clockwise.
The machine will beep or flash, let go of the buttons. Release the buttons, then turn the dial slowly, stopping at each click until you get to "off". Now, turn to any setting, then turn to off.
Now, try the machine. If it works, I'm very happy. If not, perhaps someone else can help.
Good Luck
Posted on May 04, 2011
  • 1 more comment
  • mickdraper
    mickdraper Jun 20, 2012
    Just saved me a lot of time and money plus my wife loves me even more now. Washing machine repair guy will even refund my 100 bucks after I shared this tip with him.
  • Anonymous Aug 21, 2017
    I need reset instructions of Electrolux EWF1497 HDW2 please help me..
  • mabel goodrich
    mabel goodrich Apr 23, 2021
    Different countries have different manual instructions for resetting the operational procedure. Thanks for sharing the method that worked very well with washing machine repairing. You could have an Adult Cam Chat for more fun and joys around the world.
2answers
Electrolux EWF 1282 start pause button is flashing wont start a load have reset it no error messages came up have also cleaned the drain filter the manual way underneath the machine still nothing any
Hello terry_gwen - Based on the symptoms you are describing, you may either have a communication error from the main control board or the timer itself may not be operating correctly. I understand that the filter has been cleaned, however, if you noticed a humming noise, it could either be a clogged drainage hose, or it could possibly have another issue with the door lock assembly. I would personally contact a professional to accurately diagnose the washer to determine the root cause to reduce the risk of unnecessary parts.
How do i reset an electrolux 1080
E20 is an error code for a drain pump issue. The error will reset itself if the issue has been resolved. If it or another code continued to appear, then the unit has not been accurately fixed.
1helpful
1helpful
Wat is code for e20 on a ewf 1080
E20 error code measn blocked filter. Removing the blocked filter you have to remove the water from inside by using the small flexible tube which located next to the filter at the right bottom of the machine. Then the only think it still remains was to unscrew and clear the filter.
Hope helps.
10helpful
2answers
Hi , I have an elctrolux washing machine, and it stops half way through the cycle 'saying' E20. Does anyone know waht I have to do Thanks RN
E20 is difficulties in draining for washing. which can be drain tube kinked or blocked, drain filter clogged or dirty or the pump impeller behind filter is getting jammed by a coin or cotton or anything wrapped around it, remove filter and look at back of hole and see if impeller will turn use a long screwdriver to turn it, obviously with the power off
14helpful
3answers
Error code E20 electrolux washing machine EW1280F
• E10 = there is no water filling • E20 = the water is not drained • E40 = door open
Download Manual - http://laundry.manualsonline.com/manuals/mfg/electrolux/ew_1280f.html
Electrolux EWF 1470 Error code E20
could be the element at fault or pressure chamber
1helpful
2answers
I am having problems with an electrolux 12680 W. PNC 914522501 2007 production yr. It was making a strange sound and not pumping out water. No problem, I removed the front plug and cleaned out around the...
the hose coming from tub to the pump has a filter in it.you need to pull filter out and empty it.E20 means that you have a slow drain,or clog.If the pump is noisier than ussual then you may need to replace pump.but check filter first.
20helpful
6answers
Electrolux EWF 1087 error code E60
My Electrolux washer always come up with an error code of E60, Why? can any one help
Washing Machines Logo
Top Electrolux Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
