Washing Machines Logo
Question about Electrolux Washing Machines
How do you fix e11 code?
Machine has been working, then the no water code appears.
Electrolux
  • Official Brand Answer
  • 4,342 Answers
Hello friend, thanks for your post!
I see that your Electrolux washer is giving off an "E11" error code. An "E11" stands for water is not entering, which can be several possibilities. The water supply to your home has been interrupted or water pressure may be low. Check the hoses to assure they are not kinked and the drain pipe is proper per installation. If these steps have not resolved your issue it could be a problem within the control panel and I would perform a reset on your appliance, which is disconnecting power from it for roughly ten minutes. Hopefully this helps. -Matt
Posted on Sep 11, 2014
2answers
My frigidaire washing machine displays E11 error and stops before completing washing cycle. How can I trouble shoot? I plugged and unplug it didn't help
On many machines the E11 error occurs as one or more of these connecting wires break, this may be due to excess movement from unbalanced loads. To prevent this when washing any heavy items ensure there are enough heavy items to spread around the drum to help the machine balance its load.
How to fix e10 problem on a ewf1087 washing machine
Family error code E10 is visible to customers and (could be E11 and E13 only visible in service mode) means problem with filling water.
I suggest rapid reading alarm code when appliance is in normal operating mode (e.g. during the execution of the washing programme).
Press and hold down START/PAUSE and the nearest option buttons for at least two seconds: the LEDs initially switch off, and then display the flashing sequence corresponding to the last alarm.
The alarm sequence continues as long as the two buttons are held down.
control panel ewf 1087-ltitgxxnutby230vusxroiah-3-0.jpg Before anything first check filter on solenoid valve and filter on inlet hose. Also, check is there any water inside drum, means that last drain phase is finished and pressure switch is in empty position.
E11 - Tap closed or water pressure insufficient; Drain hose
incorrectly positioned; Water fill solenoid faulty; Leaks from
pressure switch hydraulic circuit; Pressure switch faulty;
Wiring faulty; Circuit board faulty¸.
E13 - Drain hose incorrectly positioned; Water pressure
insufficient; Water fill solenoid faulty; Leaks or blockage in
Circuit board faulty.
Dado
1helpful
2answers
Zanussi wfd1257w giving E11 error on dry cycle. Is there a way to further diagnose the fault?
Hey Rich,
Error Code E11 means that your Washing machine has detected an overfill of water - over filling with water
  • Check drain pump for blockage or obstruction
  • Check drain hose for blockage or obstruction
  • Check drain pump
  • Check fill valve is not jammed open or leaking
  • Check electronic control module
Good Luck
JP
1helpful
2answers
How do I fix error code E21 on Electrolux Front loader washing machine?
It is the customer fault code. Simply turn on and turn off appliance.
E11 - problem with fill water
E21 - problem with draining water
E41 - door open
All other errors require service staff !!!
2answers
Eternal hot water heater error code e11
I cannot find what e11 means but it seems most people have just unplugged it an it came back on. Code goes away.
E11 frigidaire front load washer solenoid hums
change the water inlet valve located where the hot and cold hoses screw in to it
Error code E11
Hello Elizabeth, thank you for your inquiry!
Typically, error code E11 indicates that the water fill time is too long. This could be due to a faulty valve, clogged valve filters, kinked inlet hoses, or low water pressure supplied to unit. Also, if the drain hose is installed too deep into the house drain pipe the water may syphon as it fills. At this point, I would recommend having a service technician to diagnose the problem before investing in unnecessary parts.
I have a Frigidaire affinity washer error code reads E11. Unit immediately pauses after activating start. Troubleshooting door ssitch revealed resistance was 1320 ohms. I was told 1500 ohms should be...
Good Morning Neil, thank you for your post!
Error code e11
if its a frigidaire front load washer then code e11 indicates thats its a slow fill water problem,remove your hot and cold inlet water hoses and check the hose screens for blockage
4helpful
My Frigidaire washer is reading error code E11..how do I resolve this problem?
E11 = Long Fill Time
Check to see the water valves are opened all the way. Check water hose screens for buildup.
Open Questions:
Top Electrolux Washing Machines Experts
nu267
tina gallow
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
