Bart Caldara Posted on Dec 11, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello,I have a jetsort high speed coin sorter/counter, and I am getting a pwr fail table error. Would like to know what that means please. Thank you in advance
  • Brad Brown Dec 13, 2019
    Hi Bart Caldara, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What model?
Leroy Elliott
Level 3:
Fixya-Fanatic:
Visited the website for 90 consecutive days.
  • Advance Master 425 Answers
  • Posted on Dec 13, 2019
Leroy Elliott
Advance Master
Level 3:
Fixya-Fanatic:
Answers
425
Questions
0
Helped
137237
Points
1154
For some reason the table is not lifting
3 Related Answers
A
Anonymous
  • Posted on Dec 25, 2007
SOURCE: DigiPro drawing table error
See this article. I had this problem too and it worked like a dream.
http://www.fixya.com/support/t230271-tablet_problem
Anonymous
  • Posted on Jul 22, 2011
SOURCE: How do you turn on
There's a button on the top back right side you press.
  • 19187 Answers
  • Posted on Nov 18, 2013
SOURCE: Hello I have a whirlpool aqua steam sense 6
What is the model number?
Testimonial: "Hello Sorry the error is a f05 error, not f50. The model number is 859297015700. I've been told it's a Water temperature sensor error, but i'm not sure quite what that is, or how i fix it ? Thanks for your help Carolina"
2helpful
2answers
Emerson coin sorter will not turn on. Need manual please
Greetings,
Please reach out to your local home hardware store over the phone to request the manual from them. Tey might also be able to request the manual from an Emerson representative for you. And it would be your choice to pickup the manual at the store or have it mailed to you.
Thank you.
How do I reset a cummins jetsort 1000 coin counter
Make sure it displays "batch end", then hold down the stop button until the settings mode appear.
Total : ok
Print: down
Start batch next setting,
Sub batch: click
Clear : will exit you out of the settings once you finish.
Ensure to bag the coins you set the machine to sac if you keep it on normal it will continue beyond the bagging amount.
Brandt coin counter and sorter, looking for a manual for it, not sure of model, have a pic of it
No one can give you a manual with out a model number! There are hundreds of models. A picture would be helpful.
Call me, I may have one if I can "see" the machine.
Harry 985 / 893-52four one
1helpful
H5-01 error on sharp AR-M450N
Sharp AR-450 H5 01 Papersensordefective in the fusing unit 02 Fusing unit temperature error C1 00 MC unit malfunction C2 00 TC unit malfunction E7 00 Image Processing Unit error 01 Memory back-up battery dead 02 Laser unit problem 03 HDD defective 10 black level calibration error 11 white level calibration error 13 CCD calibration error 90 Image Processing Unit error F1 00 Lost communication with the Sorter 01 Sorter registration problem 02 Paper transport motor overloaded in sorter 04 Bin position error in sorter 05 Bin position error in sorter 06 Shift sort motor overloaded 08 Stapler position error 08 Stapler overloaded 11 Sorter problems 14 Second shift tray jammed 15 Sorter drive problems 50 Sorter not installed properly 80 No powerin sorter F2 00 ID pattern reading error 02 Toner add mechanism malfunction 31 ID pattern reading error 32 ID pattern reading error 39 Drum thermistor error F3 12 Paper does not lift in the tray 22 Paper does not lift in the tray F9 00 Printer board problems 01 Printer board problems 02 Printer board problems 03 Network card error 04 Firmware error 05 Not enough memory 10 Printer board problems 90 Printer board problems H2 00 Fusing unit temperature error 01 Fusing unit temperature error H3 00 Overheated fusing unit 01 Overheated fusing unit H4 00 The fusing unit doesn't heat up 01 The fusing unit doesn't heat up H5 01 Papersensordefective in the fusing unit 02 Fusing unit temperature error L1 00 Scanner position error L3 00 Scanner position error L4 01 Main motor drive overloaded L6 10 Polygon mirror motor not up to speed L8 01 Zero cross signal error 02 Zero cross signal error U2 00 EPROM error 11 EPROM error U4 02 Duplex not working properly 03 Duplex problems U5 00 Communication with the ADF is lost 01 Registration sensor problem in ADF 02 Exit sensor error in ADF 03 Timing sensor problems in ADF 11 Paper feed drive overloaded in ADF U6 01 Paper lift problem in 1'st optional tray 02 Paper lift problem in 2'nd optional tray 08 Paper feed unit without power 10 PFU paper transport motor overloaded 22 Paper feed unit without power 50 Paper feed unit not installed properly 51 LCT not installed properly U7 00 Main board malfunction U9 00 Op panel problem 90 Op panel problem EE EU Low toner density in the developer EE EL High toner density in the developer FA 01 Memory back-up battery dead PC Key counter not installed
1helpful
Minolta EP4000 Error C0b62
Hello sir;that's sorter bin problem, check the sorter bins see anyone out of track not move otherwise shift motor defect.
Top Advance Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you an Advance Office Equipment and Supply Expert? Answer questions, earn points and help others
