I need to scan documents using my canon MG2520 printer but can not figure out how to do it. Help?
  • Anonymous Nov 24, 2015
    https://www.usa.canon.com/internet/porta...
teamtech
  • 108 Answers
Https://www.printerdriverforwindows.com/canon-pixma-mg2520-driver
install the drivers first then you can scan using applications or right click on printer icon and select scan
Posted on Mar 03, 2018
Gordon leland
    New Friend:
    Problem Solver:
  • 8 Answers
My CANON printer was also not scanning anything, I tried a lot to fix that but unable to fix. At last I got this linkhttp://www.printer-techsupport.com/Canon-printer-support.html I just visited and made a call on their toll free. I got instant help from a certified technician to fix my printer.
Posted on Mar 19, 2016
Alexandr Socrovisciuc
    New Friend:
You need to download MP driver for the Canon MG 2520 printer. After that the scan button and functions appear on Canon Quick Menu: Download link:gdlp01.c-wss.com/gds/3/0100005313/02/mp68-win-mg2500-1_02-ejs.exe
I took it from this page: http://otopsd.com/canon-pixma-mg2520-drivers-mac-win-linux/ After that everything works perfect!
Posted on Jan 12, 2016
Margreta
I had the same problem, never seen anything like it before. Solution:
Go to the Canon.com website and download The whole driver and software package. It gives you the whole interface to do everything the printer can do (also graphics software).
Without the graphics and software installed, all you've got is minimal printer drivers, no Canon folder, no manual, no interface, nothing.
Here's a link to the canon usa page with the download.
http://www.usa.canon.com/cusa/consumer/products/printers_multifunction/photo_all_in_one_inkjet_printers/pixma_mg3520#DriversAndSoftware
This is exactly what you need, from the download page. It takes about 15 minutes to do the full install. Good luck!
I need to scan documents using my canon MG2520 - need-scan-documents-using-canon-mg2520-qc0ssaqwy3w4umsrgezdzk5w-3-0.jpg
Posted on Jan 19, 2015
3 Related Answers
komguy
Craig Gillette
  • 2306 Answers
SOURCE: my canon mp240 printer will not scan
It won't scan unless it's connected to a computer, and has the scan software running. Will it copy a document on the glass?
Posted on Aug 03, 2009
Anonymous
  • 70 Answers
SOURCE: I have a Canon iR1600 network printer. Need scanning facility.
download the driver i will send u the link http://driverscollection.com/?H=iR1600&By=Canon
Posted on Mar 11, 2010
mace1mace
Menandro de Leon
  • 1138 Answers
SOURCE: How to scan a document using Canon MX310 to Microsoft Word
you can try it by using the scanner option on the control panel. If you are using windows operating system, go on start menu, select control panel and double click scanners & cameras. Double click the scanner online and start scanning the documents. Save it in the format you want but it is usually default as jpeg.
scanned documents usually saved as .pdf file if you run the scan option directly on the printer. By pressing the SCAN button the printer. So do not use this option if you do not want the documents to be saved as pdf files.
Posted on Aug 06, 2010
2helpful
2answers
My PIXMA2520 only prints document when scanned,and is not able to scan TO my computer Need to scan and have it appear on my computer.How can I do this?or is this printer-scanner not able to Than you
Scanning to the computer is done through the printer menu of the software you loaded to the computer when you installed the printer in the computer. The menu item you want is called "MP Navigator" and it is in printer "Canon Utilities" menu
1helpful
Why do scanned documents only display in PDF format. Why not display in WORD?
well scanned documents are best suited with pdf format since a photo scanned would lose its glamour in a word document format and thus looks good in a pdf format but there are still options for you to convert it to a word document through: http://convertonlinefree.com/PDFToWORDEN.aspx
2answers
How to scan a document with Canon Pixma printer MG2520
Maybe you should read the user's manual? I've reas cutomer's review at Amazon and looks users have no problem with the scanning feature of this printer. If you don't have the manual, get it from here:
Canon PIXMA MG2520 Manual
Maybe these videos should give you some more info:
Professor Cannon Printer Pixma MG2520 Setup and Installation Open Box
Canon PIXMA MG2520 Inkjet All in One Printer Best Seller
Unboxing Canon Pixma MG 2520
How do I scan a document with Canon MG2520?
When you installed the machine on your computer, assuming you did a standardinstallation the scanner driver and software should also have been installed. Assuming you are using a Microsoft environment ie Windoze something, you can check your scanners and cameras folder. The MG2520 should be listed in that folder. If not - re-install it. Then go to this page:
http://ugp01.c-ij.com/ij/webmanual/Manual/M/MG2500%20series/EN/CNT/cnt_scan.html
3answers
How to reset Canon mg2520 newly refilled?
Press and hold STOP or RESUME button for 6 seconds.
Where is the scan button and how do I scan?
The scan function can be performed by using either IJ Scan or ScanGear software from your PC and it is available from Canon support centre.
Follow this link and download the user manuals and software to set up the scan function.
Canon Support Drivers PIXMA MG2520
Where is the scan button and how do I start it?
Try this steps:
1. Load the document in your printer/ copier/scanner
2. On your computer, click on start (the windows logo button)
3. From the pop-up menu, click on Devices and Printers
4. From the window that opens, right-click on the printer/ scanner you loaded the document and click on the options for scan. (Make sure it is checked as the default printer)
5. A dialogue box will pop up options for you to choose and scan your document. It will be saved to a folder in the documents My Scans. Does this help?
Canon mg2520
This is usually a Word option.
In Word versions prior to Word 2007:
1.Click the Tools->Options menu item.
2.Select the Print tab.
3.Make sure Include with document/Document Properties is DEselected.
4.Click OK.
In Word 2007:
1.Click the round Office button in the upper-left corner of the window.
2.Click the Word Options button.
3.Click Display.
4.Under Printing Options, uncheck Print Document Properties.
5.Click OK.
Tom Chichester
