What does MC,MR,M-,M+ on the calculator mean and do?
taran_2005
  • 10,515 Answers
MR is Memory Recall
MC is Memory Clear
M+ is Memory add
M- is Memory subtract
These are used to add and subtract the answers to multi-step equations so you can do the small steps with the calculator, then store, change or recall the total as needed. You might add a long string of numbers in groups this way. Or you can do all operations in one parenthesis, then just store the total of each.
A good problem to illustrate this would be : (123 x 3) + (55 - 24) + (10^2) - (7 x 8) = ???
Using MR, M+ and M-, you can do each one as a group, and only store the answers. 123 x 3 = 369 so M+ to put 369 in memory. Clear it from the calculator. 55 - 24 = 31, so M+ to put this in memory and add to the 369 already there. Clear it from the calculator. 10^2 = 100, so M+ this to memory also to add it. Clear it from the calculator. 7 x 8 = 56 so M- this to SUBTRACT it from memory. Clear it from the calculator if desired. Now, when you then hit MR, you will get the total of all of these small equations in parenthesis -- 444.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 18, 2009
  • 1 more comment
  • mohika_sinha
    mohika_sinha Apr 01, 2012
  • rochelle_san
    rochelle_san Oct 16, 2012
    what about mrc? everytime i tried what you said it doesn't give me the correct answer. since my calculator does not contain mr rather it has mrc on it
  • DEESHABH SHARMA Sep 18, 2013
    helpful and effective!!!..thnks buddy..
k24674
  • Office Equip... Master
  • 8,092 Answers
M- subtracts the displayed number from the total in memory.
M+ adds the displayed number to the total allreday in memory.
For the other two, I can only guess: MC Clears memory, MR recalls from memory. But that should not be difficult to verify on your calculator.
Hope it helps.
Posted on Sep 19, 2009
Testimonial: "Problem solved. Thanks for helping."
Just Gort
    President:
  • 1,187 Answers
Those are the "Memory" function keys.
[MC] = "Memory Clear"
[MR] = "Memory Recall"
[M+] = "Add to Memory"
[M-] = "Subtract from Memory"
This is used when you want to store a set of numbers or a total, temporarily, while you do another calculation.
Try this:
1 + 2 = [M+] ( you just placed a "3" into Memory)
Now enter this:
4 + 4 = (you have "8" on the display)
Now press these three keys: - [MR] =
Your display shows "5"
What you did was to take "8" and subract "3" that you stored in Memory. That equals 5.
Go through this again and it works!
Testimonial: "Thanks I coudn't figure it out, there were no imstructions. I was also lokking for something to set the decimal point automaticly. Again thanks."
  • Just Gort
    Just Gort Sep 19, 2009
    Cool ...
    What brand is the calculator?
    Any other weird buttons?
    Thre is a caculator program on your computer, too!
    [Start]
    [Run]
    in the box, type: calc
    and press [Enter]
    You can use your mouse to click on the keys, or use the computer number keypad!
    Enjoy!
Anonymous
    New Friend:
Can the memory function be turned off?
Posted on Jul 23, 2010
3 Related Answers
Ezrahite
Rofel Lantican
  • 2632 Answers
SOURCE: What does MC, MR, &
Welcome to Fixya. Heres the meaning that you're looking for.
MC - Memory Clear. this clears all contents of the memory
MR - Memory Recall. This displays the current content in the memory
MS - Memory Save. This saves the current display to memory.
M+ - Memory Add. This adds the current figure to the value already present in memory.
Thanks for using Fixya.
Posted on May 12, 2011
k24674
  • 8092 Answers
SOURCE: Hi, are there MC, MR, M-, M+ functions in Texas
The calculator has 10 memories (0 to 9)
To store a number (13) in memory 6 type 13 [STO] 6
To erase the content of memory 6 (M6) store 0 in int: 0 [STO] 6
To recall the content of memory location M7 press [RCL]7
To operate on the content of memory location M5 the syntax is [STO] [Op] 5, where [Op] is the operation symbol [+], [-],[x], [/] [y^x]
Ex: to raise the content of memory location 4 to the power of the displayed value, you press [STO][Y^x] 4
To clear all 10 memory locations
press [2nd][MEM][2nd][CLR WORK]
In short, although you do not have the keys you are accustomed to, you have a lot more. And please do not blame me if you feel disappointed.
Posted on Apr 19, 2010
Anonymous
  • 113 Answers
SOURCE: What do calculator buttons on
Not sure what they all mean but
ON/C turns calculator on or Cancels the current entry % divides by 100 or percent MC - memory clear M+ add to what is stored in memory M- subtract from what is in memory
You can get a manual at http://www.product-support-staples.com/DisplaySKU.aspx?SKU=600516
If this was useful please give me a thumbs up
Posted on Mar 20, 2011
How do the memory keys work?
Memory keys normally work by adding and subtracting values to them. It looks like you have two memories available, memory I and memory II. (M- I M- II M+ I M+ II) You recall these values with the MR(C) keys to use them in other calculations. Finally, you can clear the memory using the MC keys. Sometimes there is not a MC key. In this case, the easiest way to clear the memory is to recall the memory, multiply it by -1, and add it to the memory. This should set it back to zero.
As an example, if we enter 5 M+ I, 10 M+ I, and then hit MR-I, we should get the answer of 15. If we then enter 13 M- I, and hit MR-I, we should now get an answer of 2. Now if we hit MC - I and then MR - I, we should get the answer of 0.
Let me know if you have any questions.
Good luck,
Paul
What does the mr mean on a calculator
What make and model calculator? On most calculators with such a button, it means "memory recall." Press the button to recall the contents of the memory.
1helpful
How can i make my TI-84 Plus calculate the MR=MC.
It is easy to find solution for this problem. Type solve(0,1Q+118,5 = 0,02Q+15,Q)
See captured image below
How do I load a number into the memory?
Enter the number then press M+.. this loads into memory. MC is mem clear..M- is mem minus. MR may be mem recall
15helpful
2answers
What does MC, MR, & MS mean?
4helpful
What do calculator buttons on Staples calculators stand for ? In particular, 0N/C, %, +/t, MC, MR, M+, M-, --> I received this giant calculator as a X-mas present (2010) I really...
How to take off mem cleared
About hearing your question it sounds like you are having problems with memory(the letter M) that is always appears on the screen of your TI-15 Explorer Calculator. So, for you to cancel it you have to press "MR/MC" button twice then finally hit the "clear" button.
hope you get it right...
3helpful
What does MR, MC,MS & M+ means in a calculator
My best guess would be this ::
MR = Memory Recall
MC = Memory Clear
MS = Memory Store (Store this number in Memory)
M+ = Add this number to the number in Memory
Charlie
Feb 11, 2011 • Vacuums
4helpful
Hi, are there MC, MR, M-, M+ functions in Texas Instruments BA II Plus calculator?
Tom Chichester
