I didn't see a specific manual for a Brandt 650.
Some general instructions at the link below:
https://bizfluent.com/how-7905076-instructions-brandt-coin-counter.html
SOURCE: need to detach the sorter from a Ricoh Aficio 650
if you open the door on the sorter look just below the top right lever there is a plate that looks like a pull lever it has a srew in it take the screw out and pull the lever this releases the locking mech to detatch the sorter..if you can see the locking brackets on the copier the lever is in the same area.. good luck A
SOURCE: Sharp SF 2030 check sorter problem
follow the small holes on the sorter trays to the bottom and top there you will find the sensors that tell the copier that ther is paper in the trays make sure that they are clean and ther is no obstruction
SOURCE: I need a manual for
Here is the only manual online for the counter.
http://www.jcmglobal.com/Libraries/Product_Manuals/CS-20.sflb.ashx
You can also contact JCM on this link below for the manual.
http://www.jcmglobal.com/en/contact/default.aspx
SOURCE: Does anyone have a service manual for a Delarue Mach 5 coin counter
Yes download it from the internet!
