Question about JVC Car Audio & Video
Most likely, your engine might not be producing the correct amount of voltage to your stereo system. It's most likely being over worked, or even your CD player needs to be cleaned. If it's the latter, try a quick burst of air duster.
Posted on Sep 26, 2019
SOURCE: i c an't set the time in my jvc kd-g120 audio cd player
Push the Sel button and hold for 3 seconds (usually displays Demo or Demo Off). Push the Station up and down button til it reads Clock H or Clock M. Turn the volume button to adjust time. Push the Sel button to quit.
Posted on Dec 07, 2007
SOURCE: JVC KD-G431 IN CAR CD PLAYER "000ZAAA" Error
I had the same problem. It started when I tried to play an MP3 track from a "Creative Zen Vision M" Media Player. The result was the same as you describe = Maddening. It was extremely annoying that the CD player did not work. I thought I had broken the equipment.
Then my wife read the product hand book , and noticed on page 2 http://jvcmobile.co.uk/documents/products/KD-G431%20Instructions.pdf it showed, where using a pen you can reset the equipment back to the original settings. I thought I might as well give a try. It worked = Fixed. Amazing. I was so relieved. Such an easy solution.
Give it a go. I reckon there is a good chance it will fix your problem, and you will also be very relieved. Just use a basic MP3 player in future. GOOD LUCK !!!
Posted on Mar 22, 2008
SOURCE: Unable to play MP3 CDs on JVC KD-G140
I had this same problem and realized after reading the manual that this model does not play mp3's. They use the same manual for the g140 and the g240 (the model which plays mp3s).
Posted on Jul 09, 2008
SOURCE: cd player clock settings
Press and hold SEL (select) button on left for 3 seconds
Select CLOCK H on the left or right side of the knob on on the right.
Adjust hour by turning the outside of the select knob
Press SEL to lock hour
Select CLOCK M on the left of right side of the knob on the right
Adjust minute by turning the outside off the SEL knob
Press SEL to lock minutes
Press DISP button
Posted on Nov 05, 2008
SOURCE: I HAVE A JVC KD-G321 CAR RADIO/CD PLAYER
I had the same problem, the cd refused and radio plays good, with JVC KD G321. I have disconnected the switches behind the radio and also disconnected the antenne (do not forget the antenne) and it played the cd again.
Jan (my english is not so good, i hope my solution is better.
Posted on Sep 18, 2009
Feb 15, 2012 | JVC Kd-ahd69
Jan 20, 2010 | JVC KD-G430 CD Player
Dec 30, 2009 | Car Audio & Video
Dec 14, 2008 | JVC KD-G210 CD Player
Jun 30, 2008 | JVC Sirius KD-LH300 CD Player
Jun 11, 2008 | JVC KD-G320 CD Player
May 19, 2008 | JVC 50W x 4 MOSFET CD Deck with MP3...
Oct 17, 2007 | JVC KD-HDR1 CD Player
May 18, 2007 | JVC KD-SX770 CD Player
Apr 30, 2007 | JVC KD-G120 CD Player
133 people viewed this question
Not in the car in a travel trailer and radio is brand new
