20 Most Recent JVC 50W x 4 MOSFET CD Deck with MP3 Playback and Detachable Faceplate Questions & Answers
How do i get my jvc KD-R210 out of demo mode
1) Push and hold (SEL)
2) Push (
9/20/2017 8:15:27 PM • JVC 50W x 4... • Answered on Sep 20, 2017
0answers
Mosfet 50wx4
Be the first to answer 1/29/2014 3:02:12 AM • JVC 50W x 4... • Posted on Jan 29, 2014Be the first to answer
When i insert a dvd
Cause it dosnt play DVD's :/ only cd...
7/19/2012 8:31:56 AM • JVC 50W x 4... • Answered on Jul 19, 2012
How do i get my jvc kd-r210 out of demo mode?
Press and hold the volume knob until it changes to a menu setup, by pressing the knob again once it should cycle to another option, keep pressing the knob until you get to DEMO. when you get to DEMO turn the knob as if you were turning the volume up or down and it should say DEMO OFF. there are many useful options in this menu, like sub control for low pass filtering, display options, turning the beep noise off/on, loud off/on, clock settings, and a few more
3/8/2011 2:16:22 PM • JVC 50W x 4... • Answered on Mar 08, 2011
When i put my Apple Ipod shuffle in to the jack,
it may be that your unit does not accept the shuffle. allot of car source units dont. unfortunately it has to do with the OS of the ipod. most ipods run an OS that you can search and locate tracks specificly. i would check which units are listed on your approved list of ipod compatible componants and see what is listed. otherwise i would try and run it through an aux input which generaly looks like a headphone socket.
cheers
1/11/2011 10:45:51 AM • JVC 50W x 4... • Answered on Jan 11, 2011
0answers
Will this JVC 50Wx4 MOSFET
Yes, you will need a dash kit to make it fit these can be purchased online, walmart and many car audio stores.
9/27/2010 12:56:49 AM • JVC 50W x 4... • Answered on Sep 27, 2010
My head unit. JVC KD-R210 works . but . when i put
Please look out for any error on the cd mechanism, the transport and drive. if dirt is found please clean carrefully. also wipe off any dirt using a reccommended wipe off the optical head.(Lens). there after check if the cd you are using had been warped or worn out, if so test with a good one. Look out when the fault errorr comes in if there is any indication of poweer interupption ,like when some other device or engine is started if so check the ground and positive supply. Please check if the eject key is depressed or if the button
is pressed on by accident due to any external pressure. I hope this helps. Good day
7/7/2010 11:18:56 AM • JVC 50W x 4... • Answered on Jul 07, 2010
Cd player part loads cd but then say please eject
are you trying to play a cd you burnt yourself? if so try a genuine cd and see if that work. some cd players can be picky about what type of music format they play.
1/12/2010 3:15:32 PM • JVC 50W x 4... • Answered on Jan 12, 2010
Unable to play MP3 CDs on JVC KD-G140
I had this same problem and realized after reading the manual that this model does not play mp3's. They use the same manual for the g140 and the g240 (the model which plays mp3s).
7/9/2008 5:41:30 PM • JVC 50W x 4... • Answered on Jul 09, 2008
No able to play mp3s on Car CD DECK
unfortunately the jvc radio model # kd-g140 will not play mp3 on a cd disk- it will play a mp3 player thru the aux jack on the front of the head unit- please rate my help
5/20/2008 2:17:12 PM • JVC 50W x 4... • Answered on May 20, 2008
Is there a loud function on a jvc kd s19
If there is, there will be a button on the unit marked as such.
5/11/2022 8:33:36 AM • JVC Car Audio &... • Answered on May 11, 2022
JVC KD-S5050 CD Receiver. The on/off button lights up but the unit does not switch on. Why?
Question edited for full 'make model (what it is)'. Component failure inside. Send it to a JVC service centre. https://www.manualslib.com/products/Jvc-Kd-S5050-In-Dash-Cd-Player-11711.html ..
4/30/2022 4:24:39 PM • JVC Car Audio &... • Answered on Apr 30, 2022
When hooking up a JVC KD-S36 AM/FM radio to my electric 36 V golf cart the radio will not turn on. I have power going to the red and yellow wire, and all the fuses are good
Are you routing only 12volts to the radio, some tuner if it does not burn them up to high of voltage won't allow it to power up to keep from damage it
4/16/2022 8:14:47 AM • JVC Car Audio &... • Answered on Apr 16, 2022
I need the color coded wiring diagram foor jvc kd - r370 radio
Contact JVC directly to request the diagram.
3/12/2022 4:31:22 PM • JVC Car Audio &... • Answered on Mar 12, 2022
JVC KD-X50BT check wiring/reset
Shine a flashlight up there and take a cellphone image. Or get removal keys of Amazon.
3/10/2022 4:16:13 PM • JVC Car Audio &... • Answered on Mar 10, 2022
Can I pair my android with JVC KDR336 without adaptor?
It is Bluetooth ready WHEN you connect the adapter. It says in the manual. Have a look here, and if I Google the adapter, everyone is sold out. https://www.crutchfield.ca/S-lvBqk6S0P4E/p_105KSBTA10/JVC-KS-BTA100.htmlFor Bluetooth operations, it is required to connect the Bluetooth adapter, KS-BTA100 (not supplied) to the auxiliary input jack (R-AUX/BT ADAPTER) on the rear of the unit. (page 9)• For details, refer also to the instructions supplied with the Bluetooth adapter and the Bluetooth device.Walmart SOLD OUThttps://www.walmart.com/ip/JVC-KS-BTA100-Car-audio-Bluetooth-adapter/16914351Using Bluetooth ® Devices - JVC KD-R336 Instructions Manualhttps://www.manualslib.com > ... > Instructions manualJVC KD-R336 Manual Online: Using Bluetooth ® Devices. ... For Bluetooth operations, it is required to connect the Bluetooth adapter, ... your phone...
2/23/2022 9:06:24 AM • JVC Car Audio &... • Answered on Feb 23, 2022
JVC 50W x 4 MOSFET CD Deck with MP3 Playback and Detachable Faceplate Logo
19 questions posted
Top JVC Car Audio & Video Experts
 Francisco Mauricio...
Jeffrey Turcotte
Jeffrey Turcotte
Ekse
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • JVC Car Audio & Video
Most Popular Question
get jvc kd r210 out demo mode
  • Car Audio & Video
