20 Most Recent JVC KD-R530 In Dash Stereo Questions & Answers
3answers
How to resolve miswiring problem on jvc steeo car
MIS WIRING" is displayed when there is a DC offset voltage detected at the speaker terminals ('+' and '-').
This is normally caused by connecting a '+' or '-' speaker wire to either GND or Vcc (+12V)
1. Collect cable not being used and make sure they are tapped off and reset
2. Remove a connected cable one at a time and press RESET
3. If after a cable removal and reset the error goes away, last cable removed was fault. Examine cable for short.
4. If you remove and reset all cables except for (RED, YELLOW, and BLACK) and you stilll have error, the short is internal of unit and requires service
6/7/2022 2:09:26 PM • JVC KD-R530 In... • Answered on Jun 07, 2022
How can I make it blue tooth
http://www.manualslib.com/manual/450459/Jvc-Kd-R530.html?page=10#manual According to the above link for the manual, you require a KS-BTA100 adapter that plugs into the rear of the unit Hope that helps
10/5/2015 4:31:53 PM • JVC KD-R530 In... • Answered on Oct 05, 2015
Cd stuck in player
try disconnecting battery, and reconnecting after a few seconds. It may cough up the CD as it starts itself up again.
8/30/2014 1:24:18 PM • JVC KD-R530 In... • Answered on Aug 30, 2014
0answers
I have jvc car radio sr86bt when I make a call using the alexa feature and I end the call it will not go back to the FM station shows 0000
It's possible that there is an issue with the firmware or software of the JVC car radio. You could try updating the firmware to see if that resolves the issue. It's also possible that there is a problem with the FM radio tuner itself, so you could try resetting the radio to its default settings to see if that helps. If the problem persists, you may need to contact JVC customer support or take the radio to a professional for further assistance.
3/17/2023 12:40:53 AM • JVC Car Audio &... • Answered on Mar 17, 2023
How to reset the clock on a JVC pc-110 boom box 1994 model?
To reset the clock on a JVC PC-110 boombox from 1994, follow these steps:
  1. Press the Clock Set button, located on the top of the boombox, to enter clock setting mode.
  2. Press and hold the Clock Set button until the hour digits on the display start flashing.
  3. Use the Fast Forward and Rewind buttons to adjust the hour to the correct time.
  4. Press the Clock Set button again to move to the minute digits. The minute digits will start flashing.
  5. Use the Fast Forward and Rewind buttons to adjust the minute to the correct time.
  6. Press the Clock Set button one final time to exit clock setting mode and save the new time.
Your JVC PC-110 boombox should now display the correct time.
3/3/2023 6:11:40 PM • JVC Car Audio &... • Answered on Mar 03, 2023
How to reset password for jvc kw-v850bt
The process for resetting the password on a JVC KW-V850BT car stereo may vary depending on the specific model and software version. Here are some general steps you can try to reset the password on the JVC KW-V850BT:
  1. Disconnect the battery: Disconnect the battery of your car for at least 30 seconds, then reconnect it. This will reset the car stereo to its default settings.
  2. Press the reset button: If your JVC KW-V850BT has a reset button, press it and hold it for a few seconds until the unit restarts. This should reset the password to the default setting.
  3. Check the manual: Refer to the manual of your JVC KW-V850BT to see if there are any specific instructions for resetting the password.
  4. Contact the manufacturer: If you are still unable to reset the password, contact JVC customer support for further assistance.
It's worth noting that depending on the model and software version, the option to reset the password may not be available. In that case, you would have to contact the manufacturer for further assistance.
1/12/2023 12:49:21 PM • JVC Car Audio &... • Answered on Jan 12, 2023
How to set fm channels on my jvc KD421
Tune the desired channel and press and hold the desired button until it shows stored.
1/7/2023 11:12:54 AM • JVC Car Audio &... • Answered on Jan 07, 2023
How to wiring jvc kd-r690s?
To wire a JVC KD-R690S car stereo, you will need to connect the power, ground, and accessory wires to the appropriate terminals on the back of the unit.
  1. First, locate the power, ground, and accessory terminals on the back of the unit. These are usually labeled "Power," "Ground," and "ACC," respectively.
  2. Connect the positive power wire (usually red or yellow) to the "Power" terminal on the back of the unit.
  3. Connect the negative ground wire (usually black or brown) to the "Ground" terminal on the back of the unit.
  4. Connect the accessory wire (usually blue or blue/white) to the "ACC" terminal on the back of the unit.
  5. Make sure that all of the wires are securely connected to the appropriate terminals.
Keep in mind that the specific wire colors and terminal locations may vary depending on your vehicle and the specific model of the JVC KD-R690S car stereo. You may want to consult the owner's manual or a wiring diagram for your vehicle and the stereo to make sure that you are connecting the wires to the correct terminals. If you are having difficulty wiring the JVC KD-R690S car stereo or if you have any other questions, you may want to consult a professional installer or JVC customer support for further assistance.
12/24/2022 12:20:32 PM • JVC Car Audio &... • Answered on Dec 24, 2022
Room for speakers
Hello jarvis40,
You did not say exactly what improvements you want to make, what your budget is, nor if you are looking for a stealth install.
First I'd recommend that you look at what some other owners have done and see what you like. The MR2 Owners Club Forum would be one place to start. Many times you will find unbiased reviews of specific gear. There are installs documented with photos, and detailed step-by-step procedures. Generic car audio forums are also good. For comparing equipment and pricing, you simply cannot beat Crutchfield. The prices at Crutchfield are generally lower than you will find at your local audio dealer, but somewhat higher than other online stores. But they are excellent for doing research and if you do buy from them, you will find that the extra dollars paid buys you the absolute best service available.
If you're looking just to add an amp and a sub or two, and want a custom look instead of a "big ugly box", you might want to check out Concept Enclosures. He constructs custom boxes to fit specific places. Sort of like the JL Audio stealth box, or MTX Thunderforms, but less expensive. He has a design for the MR2.
And if you just want to change out your factory speakers, while you are browsing the Crutchfield site, check out the Focal speakers. The Utopia Be NO. 7 is simply the best 6.5 " 3-way component automotive speaker system in the world period. But if your budget won't stretch for the Focal's, consider the Alpine SPS-600C component system. They sound amazing.
Hope this helps.
12/19/2022 1:48:53 PM • JVC Car Audio &... • Answered on Dec 19, 2022
Why is my display blinking on my JVC kdr 304 car stereo
Hi, Please restart the car stereo a few times in order to attempt to overcome the issue. If that fails, then we can restart the car as well. Otherwise, you can check the fuse within the fuse box next in order to see if it's damaged at all and replace it if necessary. Thank you.
12/8/2022 1:55:33 AM • JVC Car Audio &... • Answered on Dec 08, 2022
Volume is low using hands free talk with JVC car radio. Model KW-V850
WHEN YOU ON A CALL YOU WILL SEE THE MIC VOLUME SETTING PUSH THE PLUS SIGN TIL VOLUME GOES
11/23/2022 9:33:04 AM • JVC Car Audio &... • Answered on Nov 23, 2022
2answers
What does SCM MEAN ON MY JVC CD PLAYER S590? ALSO WHAT DOES SS
Hi, scm might stand for skip-continuously-mode where songs play in no particular order. To be sure, we would need to look at the list of modes in your device's manual. These are where all acronyms are usually explained. Thank you.
11/10/2022 4:36:27 AM • JVC Car Audio &... • Answered on Nov 10, 2022
Color of wires on JVC KD-SR61 car cd player please?
Strangely, that information is not available anywhere. Contact JVC direct. Lots of mentions, but no wiring. https://www.google.com/search?q=jvc+kd-sr61+wiring+diagram ..
10/28/2022 5:35:00 PM • JVC Car Audio &... • Answered on Oct 28, 2022
JVC KS0-X38MDBT boat, wiring fault
get a meter and test wiring
8/1/2022 2:49:08 PM • JVC Car Audio &... • Answered on Aug 01, 2022
JVC KD-R530 In Dash Stereo Logo
Popular Tags
10 questions posted
Top JVC Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Jaime Hernandez
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • JVC Car Audio & Video
Most Popular Question
resolve miswiring problem jvc steeo car
  • Car Audio & Video
