SOURCE: my pioneer deh-1900 mp will not turn on
did you use a wire harness adapter or did you connect the wires from the radio directly to the wires in the car? do you have a computer safe test light or a digital vom meter? do not use a conventional test light in this car or an analogue meter to check for power
SOURCE: Pioneer DEH-2100, no power after alternator change.
Take the unit out of the dash. In the back of the unit, disconnect/remove the wiring connector. Underneath a little "flap" on the bottom of this connector there is a small red 10V fuse. That fuse had blown, and when I replaced it the CD?radio worked just fine.
SOURCE: radio & lighter blew on 2004 scion xa
there is a fuse under the dash (on the driver side) behind the little cubby hole by your left knee the cubby pulls out and fuses are located behind replace the "ACC" fuse it is a 15 amp fuse.
SOURCE: Car Radio just stoped working.
My same model did this too. The wiring harness may have gone bad. Try direct wiring the stereo or replacing the wiring harness if you can get one. This fixed the problem for me.
SOURCE: scion xa radio - T1805 volume button stuck
I have a 2005 Scion XB radio system. The
volume down button is stuck in and won't work. I tried to "pry" around
it to try to free it, but it's like there is a spring inside that is
missing. How do I repair this.
Thanks in advance for your help!
