Depending on the model you have. Locate the carburetor (behind the air filter) on the bottom of the carburetor bowl there should be 2-10mm bolts, one of which will have a phillips head slot for screwdriver. If you say you drained the old gas out of the tank,make sure the gas valve is turned off.. then remove the bolt with the phillips head on it. When you remove the bolt, be sure to hold a cup, or whatever under the bolt, as you are draining the old yukkie gelled up gas thats been in the bowl. If you dont shut the gas valve off, and pull that bolt it will drain the entire tank. Also i tell everyone if any machine is going to sit for a period of 30 days or more, to drain the carburetor bowl and the tank to prevent any issues and stay away from gas stabilizer (on anything older than like 1994 stabil i suppose is ok but i still wouldnt). Put the bolt back into the carburetor bowl..turn gas valve back on and im willing yo bet it will run as it should..if it doesnt, remove the bolt that doesnt have the phillips slot, remove the bowl, and clean it w wire brush or sandpaper, put back together..if still no go..buy the same carb and replace entire thing. But truely think in ur case u will be in good shape with 1st thing i said to do. If any issues get back on here hope this helps. Good luck
My guess is a tiny piece of junk got stuck in the carburetor. Check the simple stuff first; it does have enough gas, you do have the gas on/off valve switched to ON, and you do have the choke open to start it.
Then watch this free video. I hope this helps!
https://www.youtube.com/watch?v=bA7K6TCM9Eg
SOURCE: Katcher pressure washer w/ 5hp Honda Engine
pour a bottle of carburettor or fuel injector cleaner in the fuel tank, replace the spark plug and set the spark pluglug gap at 0.7mm. Replace the air filter element. Also change engine oil if necessary (mobil 10w30 synthetic.
SOURCE: Honda Pressure Washer HP 5 not starting
You can try spraying some carburetor cleaner into the carb. If it starts for a minute, your carburetor need cleaning. When you added new gas did you remove the old gas first? Is the air filter clean?
SOURCE: Honda gas power pressure washer runs for awhile then cuts off.
did you pour all of the old gas out before you started to use it. Sometimes condensation builds up in gas tank when stored. You need to dump old gas an put in new gas.
SOURCE: 87 chevy 350 fuel injected pickup wont run smoothly
sounds like your egr valve is gummed up or bad. this is located behind the throttle body and has a single vaccum tube connected to it. if the diafram is still good you can remove it and clean it with WD 40 until the plunger works smooth
SOURCE: husqvarna blower quit running
clean out the carb and treat the gas with gas treatment from any car shop.redex is great stuff
