20 Most Recent Honda 8 HP Engine Questions & Answers
one major problem is how much oil u put into it,
if you over full it ,
on the down stroke the oil will compress,
forcing the oil,between the rings,
causing it too burn.
Honda 8 HP... | Answered on Mar 22, 2015
stuck valves are the main cause of breakig rocker arms
IF ENGINE IS EQUIPPED WITH NEEDLE
VALVE ON CARB TO REGULATE MIXTURE,
TRY ADJUSTING. PATIENCE, TRIAL AND ERROR WITH VALVE ADJUSTMENT WILL
PROBABLY GET YOU THERE.
Honda 8 HP... | Answered on Oct 10, 2014
Everybody had a crack at this problem, another thing would check is these engines sometimes have a primary fuel filter inside the tank itself. Drain the fuel and gently blow compressed air back through fuel line towards tank then rinse the tank out with fuel, refill and try run engine again
Honda 8 HP... | Answered on Aug 08, 2014
Hi mate, you are in the rite direction you definetely have a fuel blockage, if it is doing the same as it was before you pulled it apart and you found debris in the carby i would first be looking at the fuel screen its a little cast alloy bowl, undone with a 10mm spanner next to the float bowl on the carb and also there is another filter inside the fuel tank itself, you can blow compressed air gently back thru your fuel line to clean this out. Other than that you will have to strip the carb down again, as in the attached image you will have to remove, clean (blow out with fuel and compressed air) and reassemble the following # 5 #11 #27 and #28 ensure all these are clean and the holes they go into, take extreme care when blowing out components on a carb you can pop out your needle seat and cause damage so be gentle, and wear eye protection!
Hope this helps you out:)
Honda 8 HP... | Answered on Jul 20, 2014
is the oil over full ??? then i would suspect a crankcase breather issue which should be in the valve cover... then I would be looking at a head gasket issue, rings or all of the above
Honda 8 HP... | Answered on Dec 28, 2013
Honda 8 HP Engine Logo
162 questions posted
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Marvin
Marvin
Are you a Honda Garden Expert? Answer questions, earn points and help others
View Most Popular
Honda Garden
  • Honda Garden
Most Popular Question
air in crankcase
  • Garden
