20 Most Recent Honda 25cc 4-cycle Mini Tiller Questions & Answers
Not sure about the tines but it sounds like you overfilled the oil
Honda 25cc... | Answered on Feb 27, 2019
I'm big on synthetic oil because it protects better and lubricates better. I would be using 10/30 in the Tiller.
Honda 25cc... | Answered on Jan 15, 2019
Hello. you have some gunk in the carburator. Get a can of starter fluid or carburator cleaner aerosol and a helper. Remove the air filter and start it up. Spray a little starter fluid into the air cleaner to keep it running for three or four minutes and the problem should clear. If it does not clear the carburator will have to be disassembled, cleaned and rebuilt. j.
Honda 25cc... | Answered on Jan 14, 2019
check for a full fuel flow to the carby
indicates a low fuel level possibly float level
check that there is a heat insulation block between the head and the carby
maybe head heat is tending to boil off the carby fuel if too low a level
Honda 25cc... | Answered on Dec 18, 2017
Remove the fuel filler cap and with a bent piece of wire hook the black pipe out of the fuel tank. The filter is on the end of this.
Honda 25cc... | Answered on Mar 23, 2016
it will take oil untill you can see it near the filler cap.
Honda 25cc... | Answered on Sep 09, 2014
-What do you mean or need to know...?
Mai
Honda 25cc... | Answered on Sep 03, 2014
-Open oil filler cap or plug at front (Flat Plastic knob) then just till to the front to drain it until no drip then just re fill w/ 10w30 to full level. You're good to go.
Good luck
Mai
Honda 25cc... | Answered on Jul 24, 2014
-10 w 30 should be fine.
Mai Lor
I have a similar problem.
The first time it was cause by the ethanol in the gasoline. It deteriorated the carberater rubber membrane so that it had a crack in it. The carberater would run lean. Take off the primer bulb and there is a plastic cover that goes over the rubber membrane. Remove that cover, and check the membrane. If this has a crack, you can order another from a honda dealer. It is about 14 dollars. After that just use ethanol free gas. Search the internet for a local source.
The second problem I had developed a little later. The engine would start, but if I gave it full throttle, it would quit. It got worse and worse till it would run at all. I noticed when I loosened the Gas cap, then the engine would run. And when I loosed the cap, I heard a whoosh, like air being sucked in.
So I figured the cap wasn't breathing like it should, which cause a suction in the gas tank. So I took a diaper pin and went through the holes on the inside of the cap, and through the little rubber plug in the center of the inside of the cap, several times. This allowed the cap to breath. Now it runs great.
Honda 25cc... | Answered on May 18, 2014
It sounds like a carburetor fuel issue. Which you could try attempting to adjust the carburetor (or have someone else do such) to see if that cures the problem.
Honda 25cc... | Answered on May 17, 2014
Honda 25cc 4-cycle Mini Tiller Logo
140 questions posted
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Marvin
Marvin
Are you a Honda Garden Expert? Answer questions, earn points and help others
View Most Popular
Honda Garden
  • Honda Garden
Most Popular Question
engine bogs down when speed increased
  • Garden
