20 Most Recent Campbell Hausfeld PW2102 Gas Pressure Washer Questions & Answers
Definatley a fuel / carb problem . remove carb-remove fuel bowel turn carb upside down float should be level to carb body if not replace needle and seat. drain fuel from tank into a clear container to see if there is water in fuel (water will settle to bottom of container ) also check jet in middle of carb to see if plugged.
Campbell... | Answered on Jan 01, 2018
2kihoq9gxddaaaaaelftksuqmccaa==
You need to replace seal shown part number 3 but that is wrong pn it is t new pump body. After you remove it you might try auto parts store (not box auto stores). If there is a a number on seal body your doing good.
Campbell Hausfeld PW2002 Product Manual Pump
https://www.jackssmallengines.com/jacks-parts-lookup/manufacturer/campbell-hausfeld/pressure-washer/pw2002/pump-parts call jacks.
Campbell... | Answered on Nov 02, 2017
any anti foaming oil ,you can use multi grade but it goes milky with minute air bubbles and gives the appearance of getting water in.most manufacturers recommend anti-foaming oil
Campbell... | Answered on May 21, 2015
It's the spark plug more than likely. If engine turns but won't stay running its more than likely spark plug. If that doesn't fix its the gas. Empty gas out get some fresh gas.
Campbell... | Answered on Jul 13, 2013
it is a 4 stroke motor so it just runs on neat unleaded fuel.
oil is in the engine and this should be 30w oil
Campbell... | Answered on Jun 18, 2011
Pump regular gas and no oil mix. Your engine has a dipstick which means its a four stroke engine.
The oil goes inside the motor. For summer use I recommend 30 weight non-detergent oil.
Change it out once a season *(Beginning would be preferred). Drain the gas out at the end of the season.
Hope this helps!
Campbell... | Answered on Feb 24, 2011
The pump uses SAE20 or SAE 30 non-detergent motor oil that fills up about half way
The engine uses 10-W30 motor oil that comes a bit more than half-way up dip stick.
Do not turn washer on its side or upside down to drain oil, or oil will run into carburetor.
If you have problems starting:
read:
http://www.fixya.com/support/t6504468-craftsman_2700_psi_pressure_washer
Campbell... | Answered on Nov 09, 2010
Most pressure washers introduce soap into stream of water by the siphon method. In order for the system to siphon the pressure tip must be changed to one with large opening. Once the large tip is install, the fast moving low pressure water thru the hose and wand will draw-in soap. With the pressure tip installed soap will not be drawn-in. To spray soap and water under pressure use a large container (larger the better like clean 30 gallon trashcan) and fill with clean water and measure of liquid detergent. Use short water hose from with-in container and connect to pressure washer as normal. Keep checking water level so that washer will not run dry. Most pressue washers will **** water in quickly from container, however you can pre-fill the water hose with water to speed things up. Trailer mounted pressure washers use a very large container for water. You can estimate how log the pressure washer will take to use the water by checking the gallons per minute rating of your machine. Good luck
Campbell... | Answered on Sep 03, 2010
Campbell Hausfeld PW2102 Gas Pressure Washer Logo
46 questions posted
Top Campbell Hausfeld Garden Experts
Martin Grech
John Trevino
Tim Venetis
Are you a Campbell Hausfeld Garden Expert? Answer questions, earn points and help others
View Most Popular
  • Campbell Hausfeld Garden
Most Popular Question
kind oil
  • Garden
