Question about Dishwashers
I would replace the key pad it sounds like since everything else works.. so you hit the normal wash and start the dishwasher sits there for a min or two and turns off.. Its not recognising the start button
Posted on Sep 03, 2009
Nov 25, 2011 | Jacuzzi Pool & Spa
Hi
If clean light is blinking then it may be an
issue with heater circuit, door switch or wash pump, please reset the power to
the dishwasher. After, 5 minutes check if you are still getting the same error.
If yes, then it is a water heating fault. To resolve this error try pressing
this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air
Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub,
energy saver dry or High Temp Wash-Heated Dry-High Temp Wash-Heated Dry .
Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button
and allow it to completely drain and reset. If this doesn't work then it's an
issue with the wash pump not pumping the water past the heater efficiently or
due to lack of water to heat. Please make sure that heater is not open
circuited and is heating the water efficiently. You'll have to check the heater
using a multimeter; the meter should read between 3000 to 3300 ohms (Use
multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure
is optimum and fill valve is working fine. Hope this helps... Please post
back if you need more information.
Daniel
Aug 30, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Aug 06, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Jun 24, 2011 | GE Nautilus 24" Built-in Dishwasher
May 27, 2011 | Maytag Dishwasher
May 16, 2010 | KitchenAid 24 in. KUDI01IL - Multiple...
Nov 26, 2008 | KitchenAid 24 in. KUDS01FLSS Built-In...
Feb 16, 2008 | Kenmore 15769 Built-in Dishwasher
Feb 19, 2007 | Kenmore 24 in. 17032 Built-in Dishwasher
May 14, 2006 | Whirlpool GU2400XTP Built-in Dishwasher
330 people viewed this question
