2001 Suzuki SV 650 S Logo
Posted on Sep 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need the service manual instructions and specifications for changing the front and rear tires on my 2008 susuki sv650s
Terrie Thiessen
Level 2:
  • Expert 302 Answers
  • Posted on Sep 23, 2009
Terrie Thiessen
Expert
Level 2:
Answers
302
Questions
Helped
177104
Points
630
Flat right reat tire. Cant get a jack under to lift tire off ground to take it off. Can't lift front enough to get block under that might raise rear after lowering front. How's it supposed to come...
Hello there, the Toro 52" 27hp z master has an Exclusive Toro Z Stand on 27 hp (20.1 kw) models provides an on-board tool to simply elevate the front end of the machine and provide access to the underside of the deck.this Z stand gives access to the underside of the unit to enable you insert a jack under to change the rear tire.rockmeister_15.jpg
Here is a link to help you download the service manual, operator manual, parts catalog and setup instructions. These give more insight as regards getting the tire changed.
Hope this support has been helpful?
Thank you for visiting FixYa.
1helpful
2answers
I Had the tires rotated on my 2008 mazda cx9 at 13,000 miles in our local shop here,then i noticed a humming sound coming from front of vehicle and only when it approaches 50 to 55 mph,could it possibly be...
The noise is most likely caused by the different wear pattern on the tire that came from the rear of the car. The difference in the alignment between the front and rear suspension systems causes the tires to wear accordingly. It will take some time for the tires to wear in to their new environment. The noise should go away gradually. You should also check your tire pressure to make sure you don't have an improperly inflated tire.
2008 Harley Davidson Touring FLHT what is the normal tire pressure @
Hi, Ginger600 for this scenario you will need your service manual that has all fastener torque specs -fluid capacities and a wiring diagram on the back pages, parts fiche, and owners manual if you can not find the best tool you ever bought for your Harley, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below and for more specific information or questions at no charge please feel free to contact me at [email protected]. Good luck and have a wonderful day.
https://www.hdforums.com/forum/touring-models/950444-tire-pressure-on-08-street-glide.html
http://www.mediafire.com/file/b4h4jnz31f8r80d/2008+Harley+Davidson+Touring+Models+Service+Manual+.pdf
https://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
https://ownersmanuals2.com/harley-davidson/electra-glide-classic-2008-owners-manual-66558
https://www.6ya.com/ to speak to me personally
16helpful
3answers
Spare tire location?
With the new 2008 models, the spare tire was moved from the rear of the van to a spot below the front seats. The lug for the tire winch is located under a round cover in the floor just in front of and between the two front seats. If you look under the van, you will see the black tire-shaped cover for the spare.
Top Suzuki Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
Bob G
Are you a Suzuki Expert? Answer questions, earn points and help others
