20 Most Recent Toro 52" 27hp Z Master Zero Turn Lawn Mower Questions & Answers
Never trust the customers work. go thru all the steps for testing the charging system.
Toro 52" 27hp Z... | Answered on May 15, 2019
if this is got the 27 hp kohler engine, I know exactly whats wrong with it , due to grass and engine oil building up in a short time under cylinder heads , it actually makes a tight ball of grass and stuff there !! this holds the engine heat and ruins the ign module that's just above it there , I put two on in one season ( tractor runs 6-10 hrs day 6 days a week ) I finally gave up I bought a Kawasaki 27 hp twin and installed it , now its run for two seasons and no problems
engaging the pto has nothing to do with it , it would cut off if you just drove it around for 15 minutes
Toro 52" 27hp Z... | Answered on Sep 18, 2015
If electric start check for low battery or loose battery cables. Could be a bad starter.
Toro 52" 27hp Z... | Answered on Mar 23, 2015
It may not just slide off , but should be able to come off with hand tools.
Toro 52" 27hp Z... | Answered on Oct 15, 2014
what is question dont undrestand
Toro 52" 27hp Z... | Answered on Sep 04, 2014
you need a govenor adjustment for load for engine
Toro 52" 27hp Z... | Answered on Aug 28, 2014
one of your valves is not seating
Toro 52" 27hp Z... | Answered on Aug 18, 2014
Unplug clutch wire and remove bolt from clutch. Make sure you install it the same way it came off. Should have a notch in clutch that stops it from spinning around and ripping wire out of the clutch.
Toro 52" 27hp Z... | Answered on Aug 14, 2014
First disconnect the battery. Then unhook the wires from the starter should be one or two wires. Remove the bolts from the starter two or three bolts.
Toro 52" 27hp Z... | Answered on Jul 25, 2014
Make sure that blades are not engaged which will cause the pulley to be out further making the belt too tight for install. There may also be a tensioner pulley that may need to be released.
Mower has multiple safety switches, seat,&hydraulics, also a bad PTO switch will cause them not to start.
Toro 52" 27hp Z... | Answered on Jun 20, 2014
Check the plug and wiring connected to the seat under the seat. May have crimped or come undone. This is a safety feature on most mowers.
Toro 52" 27hp Z... | Answered on Jun 04, 2014
Toro 52" 27hp Z Master Zero Turn Lawn Mower Logo
101 questions posted
Top Toro Garden Experts
roeb
Dennis Key
Dennis Key
Marvin
Marvin
Are you a Toro Garden Expert? Answer questions, earn points and help others
View Most Popular
Toro Garden
  • Toro Garden
Most Popular Question
safety switch parking brake
  • Garden
