Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move tThe colors in the picture appear very dull, almost - 2c07611.pngdirections your convergence chips are bad and should be replaced. This is a common problem.
Solution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com.
They have put together a kits for most models. If you don't see a kit
for your set send them a quick note and they will put one together for
you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV
tubes have a liquid coolant that is used to keep them from overheating.
After many years the coolant in the blue and green tubes will become
The colors in the picture appear very dull, almost - 578ba6c.jpgcause the screen to look dull, red/orange, etc. You The colors in the picture appear very dull, almost - 65af323.jpgee halos around imageThe colors in the picture appear very dull, almost - 2c07611.pngr />Picture of a set that needs the fluid changed.
TV set after fluid change
Solution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, et
