Question about Sony KP-57HW40 57" Rear Projection Television
Sony Projector Color Display
Hi
My Sony Projector TV is displaying RED, GREEN, BLUE color separate on the screen. Can you tell me how to fix it?
Posted by mhoque1978 on
Edward
  • Sony Master
  • 3,459 Answers
These sets have several common problems which are listed below.
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find the fix here...
Sony Projector Color Display - bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Apr 03, 2010
Hi all. i got 1 toshiba led tv 32pb10e problem DOUBLE IMAGE WITH DISPLAYED RED N BLUE COLOR ONLY ON SCREEN . I TRIED REPAIRED SINCE LAST NIGHT BUT CANT . PLS HELP ME IM URGENTLY NEED REPAIR IT . TQVM
The old projector TV's are using 3 lamps for Red Green Blue....in your case the Green lamp stopped working....either the Green lamp burned or the lamp board is defective.
Mar 31, 2016 | Toshiba Televison & Video
Red color seperating
If you mean the red light is displaying offset from the blue and green then the red LCD panel inside the projector needs to be physically adjusted. If you take the projector apart you'll notice that the light source is split into red, green and blue light by passing through an optical splitter. Each color then passes through it's own LCD panel. Next, each color is joined back together by another light splitter to be projected to your screen. The red LCD panel is misaligned.
Jun 03, 2012 | NEC MultiSync MT1050 Multimedia Projector
Hi there, my dell projector 1800mp is not projecting an image on screen and it only black lines across. what should I do to fix it?.
After turning on the projector, press "+" and "-" buttons on the control panel
simultaneously for 3 seconds and release the buttons when screen goes blank.
2 Press "+" and "-" buttons again to exit the diagnostic mode.
3While in Self-diagnostic mode, the screen will run a seven-color-cycle test as
following:
Red--> Green--> Blue--> White--> Watchet Blue--> Dark Green--> Yellow.
Ensure that the colors of the test pattern are correct. Contact Dell if the colors are
not displayed correctly.
Mar 02, 2011 | InFocus LP 250 Multimedia Projector
It doesn't show red color. i tried to do factory reset. but still problem.
1.After turning on the projector, press "+" and "-" buttons on the control panel
3 While in Self-diagnostic mode, the screen will run a seven-color-cycle test as
following:
Contact Dell if the colors are not displayed correctly.
Mar 01, 2011 | Dell 2400MP DLP Projector
When the display is dark i get red and green arcs on the screen
Color arching is an easy fix. You need a screw driver and some patience removing the front panel. You will be looking for a box with 3 screws on it. This is the color gun. THe scews are Red, Green and Blue color only, however, they usually don't indicate the color on them. Turn the screw (Slighlty) till the arching is no longer there. You have to do this with the tv on.. LOL
Best Regards and Semper Fi....
Aug 06, 2010 | Sony KP-65WS500 65" Rear Projection...
Model- kp 51ws 500 manufactured january 2003 color rear video projector the screen looks 3-d, in the center of the screen it looks fine but on the edges of the screen the words or images look 3d and...
BOTH OF THE STK-392-560 convergence chips need to be replaced; there are also fuses on the power board that protect them--do not look like fuses; if you need photos of the place where the chips are and the fuses, let me know.
Repair takes about a hour and parts if purchased on EBAY will be under 25 dollars.
SD TECH
Jul 28, 2010 | Sony KP-53HS10 TV
Sony model kp46c36 rear projection tv looks like its 3d vision use to correct itself now just seeing double and colors similiar to 3d
there is a problem with your convergence circuits which align the red,green,and blue colors this must be serviced again. sorry.
Jan 30, 2010 | Da-Lite Tensioned Director Electrol 89986...
I was just given this t.v because friends couldn't figure out what is wrong with itl. The colors don't line up right,looks kinda blurry depending on the lighting of the program being watched. How do i fix...
According to the manual:
1) go to the "TV Main Menu"
2) Select "Screen"
3) Select Adjust Projection TV (obviously only if a projection TV).
This then allows you to adjust the TV's 3-colors. Selecting GREEN CENTERING brings up a control panel that lets you center the green projection tube on the screen. Selecting RED CONVERGENCE or BLUE CONVERGENCE lets you align the Red & Blue projector tubes. Centre the green projector tube 1st. Then adjust the red & blue until the test pattern on the TV screen appers white.
Good Luck!
Jun 08, 2009 | Proscan PS50700 50" Rear Projection...
Screen is green when trying to play a DVD
I think DVD player is hooked with TV via component video input.
Check component video connections and make sure each color wire connect in same correspondence color in both units, TV and DVD Player.
Red to red, green to green and blue to blue.
Dec 18, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony KF-42WE610
Sound but no picture, tv will not turn off. Light goes red but a dim overall blue screen remains and fan is still running.
Nov 15, 2007 | Sony XL-2100U Projector Lamp for...
Sony KP-57HW40 57" Rear Projection Television Logo
296 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
