Try downloading this Extract and go to mc5430DL_Win7_v2.0.1.0\English\English\setup.exe Run this setup file. Install the components that you want. If you select local and USB ensure printer is plugged in to your computer. Hope this helps.
Try cleaning the laser lens using the laser lens cleaning wand. However, it is likely that your black cartridge needs to be replaced based on the troubleshooting from the Minolta manual. Sorry,
On the 5430 DL there is an aux legal tray that can be purchased for legal printing. On a later successor the 5550 a manual feed option was included, however for the 5430 there is no option for printing legal without the extra tray being installed. On a side note, I have this tray and when not printing legal it lets me load an extra 500 sheets of letter paper which is very convenient when I need to print a bunch of sheets overnight.
Have you tried changing the printer cartridge?
The software of your printer has it's utility to clean / allign the cartridges for better printing quality.
I have to ask this question of you, just to make sure this is not an issue.Are you using a factory new ink cartridge? Please consider the following: If you are using a refilled or third party cartridge that may well be your problem.Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges. They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead. If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges Don
Hi this might work, have you tried to remove the toner and re-seat it?? If this doesnt work very carefully take the toner somewhere well ventelated preferablly outside and give it a good shake for about 15-20 seconds, this frees any clogged toner there may be.
Failing all of that you would want to try outting a new toner in and see what happens.
