My front load washer does not fill appreciably with water. The wash cycle starts almost as soon as water starts entering the chamber and the water never fills to a visible level. Is this normal?
Check your 2 in 3 out water valve part# WH13X10029, this responsible for filling of water. By the way wash cycle will not run, until washer sense enough water.
1. Turn off the water supply to both hoses. 2. Remove hoses (one at a time so you don't get them confused) 3. On the washer side - look for a removeable screen inside wher you just removed the hose. 4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes. 5. Replace the inlet screens. 6. Re-fit the hose to the machine. 7. Turn on water supply valves. 8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
To javed_iqb904, does the drum actually fill or does it seem like that water is draining out as it's filling?
To neonllama19, if it fills with the tap on and the machine off, it sounds like a defective water valve. If it never stopped filling it sounds like a defective pressure switch or hose to the pressure switch is loose or diconnected.
yes it could be but also it could more than likely be your pump not letting water out or not letting enough water out which stops the cycle try doing aload when it stops turn dial to empty and if it spins then your pump is faulty needs replcing thats the more common fault
