My Fisher Paykel top loading washer has a leak. Water is oozing out from the bottom of the machine in the front. It's enough to wet the throw rug in front of it. Any suggestions? I cannot pinpoint it to any cycle. It just starts slowly leaking during the fill cycle and seems to continue throughout.
Question edited to correct name of maker, (Fisher PayPal :>)
Question moved to one of their categories.
No clue to whether a top loader or a front loader, which is why we ask for full 'make model (what it is)'.
If it is only in the rinse cycle, and if it is a front loader it is likely to be spray of a crack in the box that is the detergent drawer and fabric softener mixer. The only way to find out is to remove the top after a wash and look for where the water came from.
May 6, 2008 - Got a small drip/leak with my GWL11 washer..... The washer is ...Small leak/drip with Fisher & Paykel GWL11 Washer (with pictures) ..... New project for a new year: Light a fire under plans for an outdoor oven and claim the best pizza in town ... Speed Queen Front Load AFN50 Washer Review - Long Post.
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... I have a Fisher Paykel GWL11 that I purchased new and have loved until this problem started. ... The machine fills with a small amount of water to saturate the clothes ...... Fault 36 is related to water leaking, but is *not* the kind of leaking from ...
Hi,It is due to a split in the flexible hose from the bowl to the pump. When machine is working, the split opens and closes, but when not operating it can be closed up enough to prevent seeing it leaking. .
Have you checked the pump on the bottom of the washer? You may have to empty the water out of the unit by hand. Then tilt the machine backward. The pump is on the bottom and no tools are needed to remove it. If the pump is wet or rusted then that should be your problem. Another way to check the pump is to remove the 2 screw ib the back of the machine on the top, and remove the electronic controlls. inside the machine is instructions to turn the pump on.
Check your water pump... When they get wet or leak, they will shut down the machine control. If you wait too long you will blow out your machine control completely. You most likely need a new water pump and it is easy to replace with no tools needed. Your part number is a 420325P and you can get one from Fisher Paykel Parts direct: http://fisherpaykelparts.net/index.php?categoryid=111&productid=3
