Televison & Video Logo
Tammy Norris Posted on Jul 01, 2019
I have a Nexxtech Ultimate UUP500. we have either a lightning strike or a power surge. I turned off my backup and then powered back up and unplugged and replugged. Still no results.
5 Related Answers
Anonymous
  • 167 Answers
  • Posted on Feb 13, 2009
SOURCE: Nexxtech UPS Battery shows full charge but won't stay on
had same problem! i discovered that the unit was defective,sorry if this is the case. good luck!
Anonymous
  • 142 Answers
  • Posted on Jan 10, 2010
SOURCE: I have a NEXXTECH ULTIMATE UUPS1000LCD Power backup
It would be best to replace it. In surge situations such as this there can be more damage than at first apparent. The unit did its job in protecting your computer, but now its protection may be compromised.
Testimonial: "THANK YOU VERY MUCH FOR YOUR OPINION"
Anonymous
  • Posted on Aug 12, 2010
SOURCE: Power surge due to lightning strike today. Comp...
Unplug it and then blow a hairdryer at the power supply for 3 minutes. Leave the lid on, just blow the hairdryer at it from the outside. Craziest trick I ever saw.
After that, turn off hibernation. And eventually, replace your power supply.
Anonymous
  • 234 Answers
  • Posted on Mar 21, 2011
SOURCE: Pioneer Elite PRO-1540HD displays 13
Have the power board professionally replaced.
gopakumarg43
  • 76851 Answers
  • Posted on Nov 12, 2012
SOURCE: tv will not power up after power surge/ lightning strike, is there a reset?
The main power supply regulator section should be troubleshooted. Might need card replacement. Contact any service technician.
When and How Should a Surge Protector Be Used on a Fixed Switch?
Common Causes of Lightning Strikes
  • Outdoor network cables or power cables are routed overhead.
  • A switch is deployed outdoors but is not properly grounded.
Damages of Lightning Strikes
  • If power cables of a switch are routed overhead in an outdoor environment, lightning strikes may burn the power supplies.
  • If network cables of a switch are routed overhead in an outdoor environment, lightning strikes may burn interfaces of the switch.
When a switch undergoes lightning strikes, overvoltage is induced by lightning on network cables and transmitted to interior of the chassis. The surge protection measures, such as lightning rod and chassis grounding cannot prevent the damage. Therefore, surge protectors or surge protection circuits are recommended.
Surge Protector Use Precautions Take the following precautions to protect a switch from lightning:
  • Ensure that the ground cable is connected to a ground bar or a ground point on the cabinet.
  • Avoid routing cables overhead in an outdoor environment. Bury cables underground or route them in steel tubes.
  • To protect network interfaces against lightning, use 8-line surge protectors (or Huawei certified 4-line surge protectors).
  • When installing a network interface surge protector, connect the IN end to terminals and the OUT end to network interfaces of the switch.
If a fixed switch is installed in a network box, follow these instructions:
  • Connect the ground cables of the switch and surge protectors to the ground bar in the network box.
  • The maximum length of a ground cable cannot exceed 40 cm, and a length of smaller than 15 cm is recommended.
  • If the network box is located outdoors and power cables are routed aerially over a long distance (more than 300 m) to the network box, it is recommended that you install a power supply surge protector in the network box. The decoupled power cable must be at least 3 m long
S2300 Switch Thunder link com
My sony bravia NSX-40GT1 is dead....no lights...nothing. (lightning strike) If I replace the P/S board will that get it up and running?
First things i would check are the powerpoint and then the fuses
a lightning strike at the powerpole may take out a fuse at the fuse box thus no power at the powerpoint,a power surge could take out the fuses on the powersupply board but check all fuses ,be sure to unplug the set from the wall first.
good luck.
Len
Our electricity went out for a few minutes, and since then the TV will not turn on. The green light is flashing. We tried resetting it by pushing a pen point into the reset hole, but it does nothing. ...
Your power outage may have been caused by a nearby lightning strike, or any number of
1000 different reasons that cause power surges, brown-outs, voltage spikes, inductive loading,
and/or utility pole breaker trips and resets (this accounts for your power loss (a pole breaker trip),
followed by restoration of power (the pole breaker automatically reset) - even plain old high electrical demand causing an overload due to air conditioning demands caused by hot weather.
When the pole breaker reset, your TV caught a power surge.
Whenever a power outage occurs, quickly power off (or better, unplug) any/all computers, TVs,
etc. that are not protected by surge-protection.
As an electrician, when someone loses an item of electronics concommitant to an electrical
anomaly, its almost
always traceable to a nearby lightning strike (or the power company provided equivalent), accompanied by inadequate surge protection for
the VCR/TV/Computer/Stereo/uninsured valuable electronic item/XBOX 360/Nintendo Wii.
Surge protection can
be provided by the consumer at the power strip (a good one with builtin MOV protection and a
warranty costs $20, whereas a zero-protection 4-outlet or 6-outlet power strip will cost $4-$5).
Your electrician can provide whole-house surge protection where a whole-house MOV-based (metal oxide varistor) surge protector, or per-circuit protection can be installed with
a GFCI breaker (or better, an AFCI breaker) can be installed.
GFCI = ground fault circuit interruptor
AFCI = Arc fault circuit interruptor
Lightning protection is especially important in Florida, which is the "lightning capital of the world."
I've never found a good solution to lightning-fried electronics (random power supply components are destroyed and/or fuse blown), other than renters insurance or homeowners insurance.
Your only real hope for an economical fix is to look for a blown fuse, and replace it.
If desperate to attempt a fix on your own, you could try replacing the entire TV power supply as a module, but even this provides
no guarantee of a fix - lightning damage can extend beyond the power supply.
When traveling, I will always unplug everything before I leave (except the security system),
and also turn off the breakers to unneeded house circuits (which kills the wall switches that
control interior lighting - forcing a burglar to use their flashlight instead of interior lighting)
which is the least convenient lightning protection, but highly effective, and cheap (free).
2helpful
Damage to equipment from power surge
yes a spike may destroyed the mov (metal oxide variastor) inside projector replace it problem will be solved spike comes in the case of storm and lightning strike apc ups are well protected from spike and surge
1helpful
I have a NEXXTECH ULTIMATE UUPS1000LCD Power backup. Around a month ago there was a lightning strike ner here and I was not able to get on line. In having a telephone tech come out, it was finally...
1helpful
2answers
My unit is in stand by but will not power on
Disconnect the main power to the receiver and let it set for 15 minutes or so, this will allow the capacitors to discharge fully. If the receiver did not suffer transformer damage, it should turn back on. If you don't have a good surge protection unit with line conditioning like Panamax or Furman, get one! It will save you $$$ in the long run. Hope this helps.
1helpful
Sears Craftsman 1/2hp Garage Door Opener
Thats one of the symptoms of a lightning strike or a power surge. Without actually being there I would suggest replacing the back-board. But as with lightning strikes and power surges sometimes other electronic components could have been damaged as well.
Surge from lightning strike damaged tv and won't turn on.
Unless you are skilled at trouble shooting power supplies , you will be better off getting a skilled repair center to repair yourset. If its repairable I have seen surges from lightning strikes make the set no longer cost effective to repair.
Top NexxTech Televison & Video Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a NexxTech Televison and Video Expert? Answer questions, earn points and help others
