Fault Code 093-314: Yellow Dispense Fault. Fault Code 093-314 occurs when an error has been detected while dispensing Yellow Toner to the Print Engine.
https://www.support.xerox.com/en-us/article/en/1134533.html
https://www.youtube.com/watch?v=nkN1v1LdTUA
SOURCE: I have a Xerox CX-700.
check it there's some obstacles in mechanical parts or the printer is dirty with ink spread inside mechanism. it needs to be clean
SOURCE: this is an error code
THE BELT HOME POSITION TOO LONG
If this fault is declared 3 times in succession, the print mode will be disabled. In order to clear this condition, reset NVM location 741-105 to 0.
[IMG]pws://file/xerox/edoc/olym/icons/arrwup.gif[/IMG]Procedure
Check that the Transfer Belt is in the center (where the IBT Belt Edge and the IBT Belt Frame are approx. the same distance from the front and rear). Center if required (see REP 9.3).
Perform ADJ 9.13 Belt Edge Learn Cycle. .................
You must use a PWS
Yellow Dispense failure.
change Y Dispense Status NVM 762-368 from 3 to 0.
replace the dispense motor
