One of the causes could be that boot-related files are missing, damaged, corrupt, or even incorrectly configured. When error code 0xc0000034 is linked to a particular file, Blue Screen is the result of a BCD error that occurs when your computer first boots up. Removing and reconnecting all hardware parts. Verify the boot order. Activate the primary partition again. status of the internal hard disc. Correct boot information (BCD and MBR) restore the boot partition.
Ever thing to look on acer.com?
here it is 1st goggle hit BTW
https://community.acer.com/en/discussion/481946/recovery-error-code-0xc0000034
HDD boot files dead , corrupted or missing.
we test the HDD first, do the smart tests if those fail the HDD is bad and there is no recovery on HDD that is dead.
OK, learn to do tests, and in the right order or long wasted labor.
others do the hope this works thing.
skipping step one test HDD
https://www.laptopmag.com/articles/fix-0xc0000034-error-windows-10
bad hdd have corrupted OS, and corrupted everything. and if true, is DOOMED.
new HDD if bad and new OS fresh installed. if HDD is bad.
fixing this is based on pure logic even computer logic.
1: back up you data first, ( ask how ? a is x10 more difficult task on a dead PC, but do ask and is whole other long post. or lean to google, "how to backup data on dead PC"
2: then run the full Smart tests in the HDD>
if this fails your HDD is bad. a FACT.
I use my Linux demo disk to test the HDD, ask how.
buy a new hdd , put it in.
3: we then get unstated windows recovery media.
and do a fresh windows install
there are the steps, any shop or tech does.
besides the BCD repair steps seen in first link.
SOURCE: I Install the window xp sp-1 than my acer laptop
This problem is because of one of the unsuitable driver. Logon to your system in safe mode and update drivers for all the hardware and restart.
Hint: keep pressing F8 while booting to show other booting options from where you can select safe mode.
