Question about Toshiba Computers & Internet
Model: satellite C55-B5100
Error code 0xc0000034 [email protected] My Toshiba laptop is showing an expected error. Error code 0xc0000034 during boot window This error code usually means a boot sector or system file problem. You can try the following steps to resolve the issue: Repair startup using the system recovery tool. Attempt a repair of the Windows installation using the installation disc. Run a system scan to detect and fix disk errors. If these steps do not work, you may need to perform a complete reinstallation of the operating system.
Posted on Feb 03, 2023
This error code 0xc0000034 usually indicates a problem with the boot configuration data (BCD) file on your Toshiba laptop.
The BCD file stores boot configuration information and is required for Windows to start up. The most common cause of this error is a missing or corrupt BCD file.
You can try the following steps and can try to resolve this issue:
1. Boot into the Windows Recovery Environment (WinRE)
2. Launch the Command Prompt.
3. Type the following command to rebuild the BCD file: "bootrec /rebuildbcd".
4. Press Enter and follow the on-screen instructions.
Note: If these mentioned steps do not resolve the issue, you may need to perform a repair install or a clean install of Windows.
