Before the power went off, I may have pressed the wrong buttons several times.
SOURCE: Kenmore Ecocycle Front Loading Washers ERR ??? LOC???
Try to fix it by unplugging the unit for few hours and then plug it back in. Good luck !
SOURCE: Frigidaire washer will not start. Get err and LOC codes.
All the lights are on, but the door lock. We have unplugged it, doesn't help. Our washer is the front load, model LTF 2140ES0.
SOURCE: lock out problem
In all likelihood all the programming has been deleted, which would default the scanner to this condition. Turn on the power & press the "Manual" button, then check the frequency. Keep doing this to ascertain if all have been deleted. If so, re-program the scanner.
SOURCE: whirlpool gold accubake system in loc mode cant get it off the ..
daddysgirl, You do not indicate the model number or the age of the stove. Early model self clean stoves used a 'oven lock door handle.' Later model stoves do not use such a handle but is electronic. I believe this is the one that you own. You also don't indicate it the door is indeed "LOCKED" or does the console just says that it is locked. If you press START... does the oven actually come on and heat to desired temperature? If not... I believe that you have a touchpad control problem. You can unplug your stove from the wall or turn off the stove's 220VAC 50 amp circuit breaker located in your main electrical panel. If possible leave off over nite and then reapply power the next morning. If you still have the same oven contol problems, then you will have to replace your oven Electronic Control Module (ECM). It sounds like the "touchpad" portion is defected but unfortunately it usually comes as a part of the ECM. The oven ECM is very expensive ($150-275. retail) plus labor to install. Hopes this helps you! HandyHenry
If you need further help, I’m available over the phone at https://www.6ya.com/expert/henry_239f63a136de60f0
