Anything in the freezer now is covered in what can only be described as a frost. Food also seems to be over frozen, like freezer burns. I have tried altering the thermostat but that doesn't seem to help.
The only way frost can form on the outside of your frozen foods is from moisture in the air entering the freezer. This happens when the door is opened exessively or your door seal is not seated firmly to the frame when the door is closed.
Fuji
Hi Dale Dibb, thank you for your inquiry!
I understand that the food inside of your Frigidaire freezer is getting frost on the inside of the packages. I would recommend turning the temperature up inside of your freezer. Additionally moisture inside of the package would cause frost to develop on the inside of the food packages.
Please assure that all possible moisture has been removed out of the food packages prior to placing the items inside of the freezer. If there is anything else that I can help you with, please feel free to reconnect! -Matt
Thsi is exactly my problem too. What is the solution?
