Every time I insert a USB device, it comes up with the message: USB device not recognized . Any solutions? I have absolutely no USB's in my slots. Thus I cannot insert anything in including to sync my mobile phone. I've already tried resetting the SMC which did not work.
SOURCE: Windows Mobile Device Center (Vista SP1 32bit) Can't sync with my IPAQ HX2490b
For the Samsung i760, disable "advanced network functionality" in the "USB to PC" setting by uncheckmarking it. Then Vista and WMDC will detect the i760 properly...
SOURCE: usb device not recognized problem
uninstall driver then turn off the PC then unplug the power cord from power socket, short its legs then leave it unconnected for 5min, then reconnect it to power socket and turn on PC and install driver it should work :)
SOURCE: ''USB: Function not allowed''
Are you dragging and dropping your files into the RECEIVED folder first? If not, you need to. From there, the phone should open up the files.
SOURCE: toshiba a135-s2356 usb ports stopped working.
Check your Device Manager
XP
my computer right click
go to properties
then go to device manager
then go to usb
Check to see if it has an x on it if it does try new softaware
by right clicking on the USB and Update
SOURCE: usb ports not recognized
Did this suddenly start to occur? Were they working before? If so, it is very simple - shut down computer, remove the battery and unplug any power source, wait a couple of minutes and reassemble and power up. Wala! I read all kinds of complicated instructions, started with the simple, and problem solved.
