Cell Phones Logo
K
Kaye Ebright Posted on Apr 10, 2019
Blu vivo xl 3 plus. Been working fine till 2:30 today my wallpaper pic went off screen & all backgrounds on every icon is black with different colors telling what it is.
Powered on& off several times went into settings, etc still doing the same thing-all my photos & message pics are very fuzzy. Any advice? When I send a message to someone they say it looks normal on their end.
sunny_rivera
Level 1:
Passionate:
Visited the website for 10 consecutive days.
Habit-Forming:
  • Contributor 8 Answers
  • Posted on Apr 10, 2019
sunny_rivera
Contributor
Level 1:
Passionate:
Habit-Forming:
Answers
8
Questions
0
Helped
1795
Points
20
I think you phone is ok, maybe you just turn on the battery saving move, or you turn the dark mode
5 Related Answers
Anonymous
  • 7752 Answers
  • Posted on Apr 15, 2008
SOURCE: Cannot send MM messaging to my email
yo should contact your mobile service provider and have them assist you
shaggyrat
Christophe Thompson
  • 1224 Answers
  • Posted on May 26, 2008
SOURCE: No pic No sound
your bulb is connected to all the audio
the bulb blew out and you need to have it replace local cuircut city has a repair man on call for this
Anonymous
  • 63 Answers
  • Posted on Jun 17, 2008
SOURCE: cant send photos
Text messages are for text only. Pictures must be sent using Multimedia Message (MMS).
Anonymous
  • 6 Answers
  • Posted on May 19, 2009
SOURCE: FullHD KDL46XBR2 Bravia: No pic, no sound
call a tv place and order a lamp for it if your not old to lift it
Anonymous
  • Posted on Sep 11, 2009
SOURCE: fuji finepix f710 lines on screen on vid will not take pics
ccd was on its way out at first , now failed
tip
Changing folder background
do you want to change the folder background?
do the following steps:
1. Open Command Prompt and set folder attribute to "system". Suppose there is a folder "Setup" in "D:\" drive, in which you want to set a wallpaper as background image. So give following command in Command Prompt:
attrib +s D:\Setup
It'll change the attribute to "system ".
2. Now open Notepad and paste following code:
[ExtShellFolderViews]
{BE098140-A513-11D0-A3A4-00C04FD706EC} = {BE098140-A513-11D0-A3A4-00C04FD706EC}
[{BE098140-A513-11D0-A3A4-00C04FD706EC}]
Attributes=1
IconArea_Image=path_of_the_wallpaper
IconArea_Text=0x00000000
Now change "path_of_the_wallpaper" to the exact path of the wallpaper which you want to set as background. Suppose the wallpaper is stored in "D:\Wallpaper\Image1.jpg", then the code will be as following:
Attributes=1
NOTE: If you copy the wallpaper in the same folder which you are editing, then you can simply put the wallpaper name in the file. e.g. if you copy the "Image1.jpg" file in "Setup" folder, then the code will be as following:
Attributes=1
"IconArea_Text" stands for the text color, you can change it to white, yellow, blue, black or any other color. You just need to know the hexa-decimal number of the color and then replace the code in "IconArea_Text" section. A few most used color codes are as follows:
Black - 0x00000000
White - 0x00FFFFFF
Green - 0x0000FF00
Blue - 0x00FF0000
Purple - 0x00C000C0
Red - 0x000000FF
Yellow - 0x0000FFFF
Indigo - 0x00FFFF00
3. Now save the file with name "Desktop.ini" (including quotes) and copy the file in the desired folder which is "Setup" in our example.
4. Thats it. Close the folder and re-open it. Now it should show the wallpaper as background.
on Sep 10, 2010 • Computers & Internet
I've had a slim PS3 for a few years now and just today, shortly after a usual system update, it started flickering constantly. Not the whole screen is affected but only some especially bright colors, e.g....
First, back up all of your saved data to an external source. Then, to a factory default reset of the system and redownload the update. Check to see if problem persists, if not, copy back all of your saved data and you should be good to go.
How to change homescreen color in iphone 4?
Settings->Light and Wallpaper
then click the pic under flowlling the wallpaper to choose a pic to as new Wallpape
If just like to change the color, you can just download a same pic with different color, or edit the pic to different color
Can not change the wallpaper
1. Right-click on your desktop.
2. Click "Personalize"
3. Click on the desktop background icon at the bottom of the window.
4. Choose desired pic.
5. Hit OK or Apply.
I cant change my desktop background ..
To change the desktop background:
1. Go to Start>Control Panel>Appearance and Personalization>Change desktop background.
2. This will bring up picture location : desktop background. You will see boxes next to all the different pictures that you can select as wallpaper.
3. Select the box next to the picture that you want to choose as your wallpaper(this will put a check in it.)
4. If you want the picture to fill the screen, under picture position, select "Fill."
5. Click "Save Changes." in the lower right of the window.
Another way to change the wallpaper-
1. Right click an empty spot on your desktop.
2. Click on Personalize. (This will bring up the personalization window with themes in the main window.
3. Click on the blue link "Desktop Background"
3. This will bring up picture location : desktop background. You will see boxes next to all the different pictures that you can select as wallpaper.
4. Then follow steps 3-5 above.
Hope this is helpful-Thanks for using FixYa.
I would like to delete wallpaper pic from my screen
if you want to delete wallpaper from desktop , first go to the
desktop > right click > select properties > the display properties will appear then select desktop option then select "none" option on the background menu and press apply ,the desktop background will appear blank ,you can also choose color of the background from the color box in the same menu
Can't change wallpaper
I have a suggestion since i had the same problem and still do. The resolution size on this screen is 130 by 130. I uploaded some thumbnails exactly 100 by 100 half of them went to the backround so try smaller pics. and different sizes . There has to be certain resolution combined with certain colors but IDK i havent competely figured it out. And you can't send pics directly to the backround they just appear as you upload IDK Try n figure the right size n color Good luck.
3answers
Screen saver
A single image cannot be set as a screensaver unless you are running some kind of slideshow screensaver software. Single images can only be set as background or wallpaper.
Display images missing on MP3, background black!
You can set one of your own pictures as the background by viewing it and holding down the center touch pad button. The bottom of the screen will say Set Wallpaper and you can let go of the button. now that picture will be set as your background image
Top Blu Cell Phones Experts
Jean Thiebaux
ADMIN Andrew
ADMIN Andrew
Stan Ford
Are you a Blu Cell Phone Expert? Answer questions, earn points and help others
