20 Most Recent Samsung X15 Notebook Questions & Answers
Could be a defective hard drive. Another option is to download a "live CD" version of linux and attempt to run the system from that to verify if the hard drive is good. If the hard drive is good then do a low level format and then re-attempt your XP install.
Samsung X15... | Answered on Jan 05, 2018
Run CHKDSK/F as soon as possible then a registry repair programme.
Samsung X15... | Answered on Nov 02, 2013
Use a computer that has Internet connection to download the Samsung drivers and then copy the drivers to an USB memory stick to install on your Samsung laptop.
You can download the device drivers from the Samsung WEB site. Please click on this link and select your model computer/notebook and the Windows drivers you require :-. http://www.samsung.com/us/support/
Samsung X15... | Answered on Sep 02, 2012
you will need a new Windows cd with a program to boot up the system again for the manufactures do not give you one when purchased.
Samsung X15... | Answered on Jul 10, 2011
To change the desktop background:
1. Go to Start>Control Panel>Appearance and Personalization>Change desktop background.
2. This will bring up picture location : desktop background. You will see boxes next to all the different pictures that you can select as wallpaper.
3. Select the box next to the picture that you want to choose as your wallpaper(this will put a check in it.)
4. If you want the picture to fill the screen, under picture position, select "Fill."
5. Click "Save Changes." in the lower right of the window.
Another way to change the wallpaper-
1. Right click an empty spot on your desktop.
2. Click on Personalize. (This will bring up the personalization window with themes in the main window.
3. Click on the blue link "Desktop Background"
3. This will bring up picture location : desktop background. You will see boxes next to all the different pictures that you can select as wallpaper.
4. Then follow steps 3-5 above.
Hope this is helpful-Thanks for using FixYa.
Samsung X15... | Answered on Apr 30, 2011
sounds like an issue with your hard drive. you could try running chkdsk /r either by removing the drive and connecting it to another computer as an axternal drive using a usb hard drive adapter or using something like the hirens boot disc, going into mini xp and do the check there.
http://www.hirensbootcd.org/download/
Samsung X15... | Answered on Apr 09, 2011
You can download drivers from the Samsung WEB site. Pleaseclick on this link and select your model computer/notebook and the Windows XPor Vista drivers you require :-. http://www.samsung.com/us/support/
Samsung X15... | Answered on Mar 31, 2011
You can download the Drivers for X15 from Samsung Official Support. Click here for Latest Audio Drivers for XP.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Samsung X15... | Answered on Dec 31, 2010
reload operating system
Samsung X15... | Answered on Aug 22, 2010
It is possible but it's usually cheaper to replace the computer.
Samsung X15... | Answered on Aug 07, 2010
your problem may have be a hardware problem or a firmware problem
before assuming that your optical drive has failed which requires to get the item replaced, try to do a firmware update as described on link below, review the info and make sure that it applies to your system first:
dvd drive no longer works correctly after update from samsumg update plus
Samsung X15... | Answered on May 06, 2010
Hibernation is giving you issues
dissable hibernation in windows power options and you should be good
Hibernation has been an issue since windows began
Samsung X15... | Answered on Sep 19, 2009
Hi, you do not mention whether you have tried the usual plug fuse etc.
You also don't mention what make/model the PC is, the picture against the problem is of a laptop so I will assume this is what you have.
A common problem is, that if your battery dies it can sometimes cause the laptop not to start. The 1st step will be to remove the battery & try to run it with just the power cord connected, if this works then it means buying a new battery.
If not & you have checked the power socket/fuse etc then I'm afraid it's a visit to the PC doctor.
Samsung X15... | Answered on Sep 16, 2009
turn off the laptop, phsically take out the drive from the computer. Then put it back in and make sure it snaps into place. The turn on the computer and go into the BIOS. It should show up in there now and if it does then it should show up in windows as well.
If you do this and it still doesn't show up in the BIOS, then the drive is bad and would need to be replaced but I feel once you reseat the drive back into the slot, then the laptop should see it again.
Ben
Samsung X15... | Answered on May 18, 2009
if there wasn't a administrator, then just push enter...
plus you are going into the wrong repair.
1st option in windows setup press enter to continue, then it'll ask you to press F8 to agree.
then it'll search for old installations of windows, when and if it finds one it'll then come up with an option to reapiar...
Good luck
Samsung X15... | Answered on Apr 27, 2009
Samsung X15 Notebook Logo
46 questions posted
Top Samsung Computers & Internet Experts
Ekse
ThaMp3Doctor
ThaMp3Doctor
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
X Samsung
  • X Samsung
Most Popular Question
samsung x15 plus motherboard
  • Computers & Internet
