Tip & How-To about Computers & Internet
Do you want to change the folder background?
do the following steps:
1. Open Command Prompt and set folder attribute to "system".
Suppose there is a folder "Setup" in "D:\" drive, in which you want to
set a wallpaper as background image. So give following command in
Command Prompt:
attrib +s D:\Setup
It'll change the attribute to "system
2. Now open Notepad and paste following code:
[ExtShellFolderViews]
{BE098140-A513-11D0-A3A4-00C04FD706EC} = {BE098140-A513-11D0-A3A4-00C04FD706EC}
[{BE098140-A513-11D0-A3A4-00C04FD706EC}]
Attributes=1
IconArea_Image=path_of_the_wallpaper
IconArea_Text=0x00000000
Now change "path_of_the_wallpaper" to the exact path of the
wallpaper which you want to set as background. Suppose the wallpaper is
stored in "D:\Wallpaper\Image1.jpg", then the code will be as following:
Attributes=1
NOTE: If you copy the wallpaper in the same folder
which you are editing, then you can simply put the wallpaper name in the
file. e.g. if you copy the "Image1.jpg" file in "Setup" folder, then
Attributes=1
"IconArea_Text" stands for the text color, you can
change it to white, yellow, blue, black or any other color. You just
need to know the hexa-decimal number of the color and then replace the
code in "IconArea_Text" section. A few most used color codes are as follows:
Black - 0x00000000
White - 0x00FFFFFF
Green - 0x0000FF00
Blue - 0x00FF0000
Purple - 0x00C000C0
Red - 0x000000FF
Yellow - 0x0000FFFF
Indigo - 0x00FFFF00
3. Now save the file with name "Desktop.ini" (including quotes) and copy the file in the desired folder which is "Setup" in our example.
4. Thats it. Close the folder and re-open it. Now it should show the wallpaper as background.
Perform the following steps to reset the Windows Update component.
1. Stop the Background Intelligent Transfer Service and the Automatic Updates service. To do this, follow these steps:
a. Click Start/All Programs/Accessories. Right click
'Command Prompt' and select 'Run As Administrator'. Click 'Continue' on
the UAC prompt.
b. At the command prompt, type the following commands, and then press ENTER after each command:
net stop wuauserv
net stop bits
2. Rename the "Catroot2" folder. To do this, follow these steps:
Type the following commands, and then press Enter after each command.
net stop cryptsvc
ren %systemroot%\System32\Catroot2 oldcatroot2
net start cryptsvc
3. Rename the "SoftwareDistribution" folder:
Type the following command, and then press Enter.
ren %systemroot%\SoftwareDistribution SoftwareDistribution.old
4. Register the files that are used by Windows Update and Microsoft Update. To do this, follow these steps:
a. At the command prompt, type the following commands,
press ENTER after each command, and then click OK every time that you
receive a verification message:
regsvr32 wuapi.dll
regsvr32 wuaueng.dll
regsvr32 wucltux.dll
regsvr32 wups2.dll
regsvr32 wups.dll
regsvr32 wuwebv.dll
5.
Start the Background Intelligent Transfer Service, the Automatic
Updates service, and the Event Log service. To do this, follow these
steps:
a. At the command prompt, type the following commands, and then press ENTER after each command:
net start bits
net start wuauserv
net start Eventlog
exit
Reboot the computer and try Windows Update again. That should get update working gain but your update status may change a bit so you may have to rerun update a few times.
